Intel® C++ Compiler
7779 Discussions
identifier "MB_LEN_MAX" is undefined when -ffreestanding
Alexey_S_Intel2
Hi!
Why the following program fails to compile with the option -ffreestanding? (Without -ffreestanding there is no errors.)
//test.cpp
#include <climits>
int main() {
char buf[MB_LEN_MAX];
return 0;
Command:  icpc test.cpp -ffreestanding -o test.exe
Output:
 error: identifier "MB_LEN_MAX" is undefined
Viet_H_Intel
Seems like a compiler issue. I will report it to the compiler team.
Can you #include"/usr/include/limits.h" as a workaround?
Viet
Viet_H_Intel
I've reported this case CMPLRLIBS-2739
Alexey_S_Intel2
Hi, Viet!
No, I'm not sure that we can do it. But we may refrain from using the option -ffreestanding.
Our goal is to drop the dependency on libirc.so. The icpc optimizes some code and places the calls to __intel_fast_memcpy (as well as some other __intel_fast_-functions) in our library, which in turn bring us the unacceptable dependency on libirc.so.
So we just need to find a way to drop the dependency on the libirc.so (and we can not link in the static version of libirc library as well). Could you please provide us with any solution?
Viet_H_Intel
You can try  -fno-builtin to see if it helps; but to avoid dependency on Intel shared libs, you would need to link in statically (-static-intel)
