Dear all,
I have problems building Cmake 3.11.2 with Intel 17up5 compilers. The same build with GCC 4.8.5 works without any issues. So it looks like this is something specific to Intel compilers, as opposed to being a bug in CMake config/build.
Error I have are:
59 errors found in build log: 1411 ^ 1412 1413 /tmp/iwtm108/spack-stage/spack-stage-p0hLlQ/cmake-3.11.2/Source/kwsys/ProcessUNIX.c(1726): warning #266: function "sigprocmask" declared implicitly 1414 if (sigprocmask(SIG_BLOCK, &mask, &old_mask) < 0) { 1415 ^ 1416 >> 1417 /tmp/iwtm108/spack-stage/spack-stage-p0hLlQ/cmake-3.11.2/Source/kwsys/ProcessUNIX.c(1726): error: identifier "SIG_BLOCK" is undefined 1418 if (sigprocmask(SIG_BLOCK, &mask, &old_mask) < 0) { 1419 ^ 1420 1421 /tmp/iwtm108/spack-stage/spack-stage-p0hLlQ/cmake-3.11.2/Source/kwsys/ProcessUNIX.c(1745): warning #266: function "sigprocmask" declared implicitly 1422 sigprocmask(SIG_SETMASK, &old_mask, 0); 1423 ^ 1424 >> 1425 /tmp/iwtm108/spack-stage/spack-stage-p0hLlQ/cmake-3.11.2/Source/kwsys/ProcessUNIX.c(1745): error: identifier "SIG_SETMASK" is undefined 1426 sigprocmask(SIG_SETMASK, &old_mask, 0); 1427 ^ 1428 1429 /tmp/iwtm108/spack-stage/spack-stage-p0hLlQ/cmake-3.11.2/Source/kwsys/ProcessUNIX.c(1787): warning #266: function "sigprocmask" declared implicitly 1430 sigprocmask(SIG_SETMASK, &old_mask, 0); 1431 ^ 1432 >> 1433 /tmp/iwtm108/spack-stage/spack-stage-p0hLlQ/cmake-3.11.2/Source/kwsys/ProcessUNIX.c(1787): error: identifier "SIG_SETMASK" is undefined 1434 sigprocmask(SIG_SETMASK, &old_mask, 0); 1435 ^ 1436 1437 /tmp/iwtm108/spack-stage/spack-stage-p0hLlQ/cmake-3.11.2/Source/kwsys/ProcessUNIX.c(1407): warning #266: function "kill" declared implicitly 1438 kill(-cp->ForkPIDs, SIGINT); 1439 ^
Denis.
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Can you try to compile this small test case? I didn't see any problem on my machine.
$ cat t1.c
#include <stdio.h>
#include <signal.h>
int main()
sigset_t tmp, tmp1;
sigprocmask( SIG_BLOCK, &tmp, &tmp1 );
return 0;
$ icc t1.c -V -O2
Intel(R) C Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0.5.239 Build 20170817
I confirm the problem with building cmake. The reason for that is that some time ago cmake started adding flag -std=c11 instead of -std=gnu11. With -std=c11, the compiler (as it apparently should) defines __STRICT_ANSI__, which stops the preprocessor from defining the macro SIG_BLOCK when processing signal.h. The argument of the developers of cmake is the following: "Intel does not support a 'gnu11' standard flag, only 'c11'." I couldn't find anything regarding -std=gnu11 anywhere in the compiler's documentation but the flag with this value is actually accepted and obviously respected by the compiler. Thus, the question is whether -std=gnu11 is officially supported.
