Intel® C++ Compiler
7931 Discussions
identifier "__builtin_expect" is undefined
DLake1
please explain.
Judith_W_Intel
This is a GNU builtin (an extension to the GNU compiler) described here:
http://gcc.gnu.org/onlinedocs/gcc/Other-Builtins.html
I believe we make this available in our Windows compiler (icl) as well, although Microsoft does not.
Judy
TimP
Black Belt
To begin with, the answers for Windows (in short, define it away) are different from those for linux or Mac.   Did any of the web search results (too many to discuss here) relate to your question?
The feature may have been added to icc to support linux kernel builds.  That doesn't mean it's a good idea to use it in your own code.
DLake1
I'm using Windows 7 x64 and Intel compiler v14 the code is from quicklz.c here: www.quicklz.com/download.html
Judith_W_Intel
Judy
SergeyKostrov
Valued Contributor II
>>...I believe we make this available in our Windows compiler (icl) as well... It looks very interesting and could you specify from what ICC version is it supported?
SergeyKostrov
The builtin_expect is used for limit checks. Also, If interested look at GCC headers since there are lots of examples of how builtin_expect is used.
emmanuel_attia
This directive is perfectly usable across Linux or Windows with that kind of macro
#if defined(__GNUC__) || defined(__ICL) || defined(__clang__)
#define EXPECT(x, y) (__builtin_expect((x),(y)))
#else
#define EXPECT(x, y) (x)
#endif
Right now only Microsoft C++ does'nt support it and with ICL (Windows Intel Compiler), it is very effective (it does what it's expected to).
