hi, guys.
I've installed Intel c++ compiler (Linux Version) under FC6 (even if it is not supported officailly) w/o any major problems.
My first code I tried to compile starts with:
#include
#include
#include
The errors I got:
/opt/intel/cc/9.1.045/include/c++/xthreads(13): error: identifier "class" is undefined
class _Atomic_counter
/opt/intel/cc/9.1.045/include/c++/xthreads(14): error: expected a ";"
/opt/intel/cc/9.1.045/include/c++/xthreads(34): error: identifier "class" is undefined
class _Lockit
.... and so on (appox. 100 errors of such a type)
It seems to that Intel c++ compiler do not understand c++ language).
How to fix this problem? Does anyone know?
thanQ.
#include
#include
#include
The errors I got:
class _Lockit
thanQ.
There're two different drivers for C and C++. In your case, you should use "icpc" to compile.
Before using "icpc", should run the iccvars.sh or iccvars.csh to set up the environment.
Jennifer
I am having the same kind of problem with MSVC 2010 Ultimate on Windows 7. What should I do?
Check that you are compiling as C++ (e.g. by using a file name such as yourfile.cpp). Such a problem might be expected with a file named .c or .C (since you are on Windows).
or you can add /TP to tell the compiler to treat the file as a C++ code file.
Jennifer
