Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
#import does not work after compiler update
Przemysław_O_
after update of Intel C++ compiler and Visual Studio, the #import statement does not work anymore and causes INTERNAL COMPILER ERROR.
Repro:
C++ Console Application Project with:
// ImportCOM.cpp : Defines the entry point for the console application.
#include "stdafx.h"
#import "LicProtector500.dll"
int main()
    return 0;
produces as output:
1>------ Rebuild All started: Project: ImportCOM, Configuration: Debug Win32 ------
1>stdafx.cpp
1>ImportCOM.cpp
1>59242.cpp
1>c:\program files (x86)\microsoft visual studio\2017\enterprise\vc\tools\msvc\14.15.26726\include\comdef.h: : error C1001: An internal error has occurred in the compiler.
1>(compiler file 'msc1.cpp', line 1518)
1>Internal Compiler Error in C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.15.26726\bin\HostX64\x86\cl.exe.  You will be prompted to send an error report to Microsoft later.
1> To work around this problem, try simplifying or changing the program near the locations listed above.
1>Please choose the Technical Support command on the Visual C++
1>INTERNAL COMPILER ERROR in 'C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.15.26726\bin\HostX64\x86\cl.exe'
1> Help menu, or open the Technical Support help file for more information
1>    Please choose the Technical Support command on the Visual C++
1>Done building project "ImportCOM.vcxproj" -- FAILED.
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
Error on VC 15.8.8 & Intel C++ 2018.5.274
Under VC 15.7.6 & Intel C++ 2018.3.210 works fine.
Viet_H_Intel
The VC 15.8.8 just released about a week ago, after Intel Compiler Update 4 released.
Can you verify if the problem still occurs on older VS version (15.7.6)?
I will try to find a system with the same setup to reproduce.
Viet
Przemysław_O_
It works fine with 15.7.4.
Przemysław_O_
I have tested this issue with VC 15.9.1 and the problem with import still exists.
Intel® Parallel Studio XE 2018 Update 5 Composer Edition for C++ Windows* Integration for Microsoft* Visual Studio* 2017, Version 18.0.31.15
1>stdafx.cpp
1>ImportCOM.cpp
1>40842.cpp
1>c:\program files (x86)\microsoft visual studio\2017\enterprise\vc\tools\msvc\14.16.27023\include\comdef.h: : error C1001: An internal error has occurred in the compiler.
1>Internal Compiler Error in C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.16.27023\bin\HostX64\x86\cl.exe.  You will be prompted to send an error report to Microsoft later.
1>INTERNAL COMPILER ERROR in 'C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.16.27023\bin\HostX64\x86\cl.exe'
Have you send an error report to Microsoft?
Is there any workaround?
AndrewC
I am all for continuous delivery but Microsoft just keeps breaking things release after release. They are up to 15.9.2 now.
Przemysław_O_
This error occur also with:
Intel® Parallel Studio XE 2019 Update 1 Composer Edition for C++ Windows* Integration for Microsoft* Visual Studio* 2017, Version 19.0.6.15
1>stdafx.cpp
1>ImportCOM.cpp
1>89842.cpp
JenniferJ
It's likely a change in the VS. We don't compile "import" but rely on VC to do. It's probably an issue in the integration between ICL and MSVC with newer MSVC.
is the code built ok with VC?
How about try the workaround:
  • build with VS to get the .tlb, and import it.
I'll do a quick test as well.
Jennifer
JenniferJ
Starting from scratching on creating a dll project and a console project, it works fine using VS2017 and ICL 19.0.1 (update 1).
But using the LicProtector500.dll, icl gaves an error.
Is LicProtector500.dll created from an older VS?
Jennifer
Przemysław_O_
I have tested it already with VC 15.8.x and 15.9.x combined with Intel 2018.x and 2019.x and always become that internal compiler error.
VC without Intel works fine.
LicProtector is 3rd party library (https://www.mirage-systems.de/en/). I suppose it was created with an older version of VC, but I use it as COM object.
Przemek
