Intel® C++ Compiler
7833 Discussions
improper UTF-8 characters handling by ICC on Windows
sav
Hello, everyone,
Fot ICU4C build using ICC on Windows got error:
sh-4.4$ (INSTALLDIR="$PWD/../../ICC64RH" && (CC="icl" CFLAGS="-MD" CXX="icl" CXXFLAGS="-MD" LD="xilink" ./configure --prefix="$INSTALLDIR" --disable-debug --enable-release --enable-shared --disable-static >_configure.log && make >_make.log) 2>_stderr.log)
[snip]
sh-4.4$ make tests
[snip]
icl   -DHAVE_DLOPEN=0 -DU_HAVE_ATOMIC=1 -DU_HAVE_MMAP=0 -DU_HAVE_DIRENT_H=0 -DU_HAVE_POPEN=0 -DU_HAVE_STRTOD_L=0  -DU_RELEASE=1 -D_CRT_SECURE_NO_DEPRECATE -I. -I../../common -I../../i18n -I../../tools/toolutil -I../../tools/ctestfw -DUNISTR_FROM_CHAR_EXPLICIT= -DUNISTR_FROM_STRING_EXPLICIT= -DUCHAR_TYPE=char16_t -DU_ATTRIBUTE_DEPRECATED= -DWIN32 -DCYGWINMSVC -D'U_TOPSRCDIR="../../"' -D'U_TOPBUILDDIR="/c/libICU4C-59.1/build/source/"' -MD   -GF -nologo -EHsc -Zc:wchar_t -c   -Forbbitst.o rbbitst.cpp
rbbitst.cpp
rbbitst.cpp(1282): error: too many characters in character constant
              if (c == u'???') {
compilation aborted for rbbitst.cpp (code 2)
make[2]: *** [../../config/mh-msys-msvc:142: rbbitst.o] Error 2
make[2]: *** Waiting for unfinished jobs....
make[2]: Leaving directory '/c/libICU4C-59.1/build/source/test/intltest'
make[1]: *** [Makefile:68: all-recursive] Error 2
make[1]: Leaving directory '/c/libICU4C-59.1/build/source/test'
make: *** [Makefile:213: tests] Error 2
which relate to code:
if (c == u'•') {
in the specified file and compiler option '-utf-8' in MSVC toolchain (both appeared simultaneously in ICU4C 59.1).
ICC doesn't support this option and throw warnings:
icl: command line warning #10006: ignoring unknown option '/utf-8'
Similar error could be reproduced using MSVC, if ICU was built without '-utf-8' option:
sh-4.4$ (INSTALLDIR="$PWD/../../MSVC64RH" && (CC="cl" CFLAGS="-MD" CXX="cl" CXXFLAGS="-MD" LD="link" ./configure --prefix="$INSTALLDIR" --disable-debug --enable-release --enable-shared --disable-static >_configure.log && make >_make.log) 2>_stderr.log)
[snip]
sh-4.4$ make tests
[snip]
make[2]: Entering directory '/c/libICU4C-59.1/build/source/test/intltest'
cl   -DHAVE_DLOPEN=0 -DU_HAVE_ATOMIC=1 -DU_HAVE_MMAP=0 -DU_HAVE_DIRENT_H=0 -DU_HAVE_POPEN=0 -DU_HAVE_TZNAME=0 -DU_HAVE_STRTOD_L=0  -DU_RELEASE=1 -D_CRT_SECURE_NO_DEPRECATE -I. -I../../common -I../../i18n -I../../tools/toolutil -I../../tools/ctestfw -DUNISTR_FROM_CHAR_EXPLICIT= -DUNISTR_FROM_STRING_EXPLICIT= -DUCHAR_TYPE=char16_t -DU_ATTRIBUTE_DEPRECATED= -DWIN32 -DCYGWINMSVC -D'U_TOPSRCDIR="../../"' -D'U_TOPBUILDDIR="/c/libICU4C-59.1/build/source/"' -MD   -GF -nologo -EHsc -Zc:wchar_t -c   -Forbbitst.o rbbitst.cpp
rbbitst.cpp
rbbitst.cpp(1282): error C2015: too many characters in constant
As for mingw-w64, it doesn't reproduce this error even without '-fexec-charset= and -finput-charset=' options.
Using undocumented ICC option '-Qoption,cpp,"--uliterals"' (see threads ICC v13 Beta Questions, C++11, Intel Parallel Studio 13 XE & Unicode String Literals, etc.) doesn't solve the issue.
Since ICC on Windows imitates MSVC, is it possible to add him '-utf-8' option support? It would make behavior of ICC on Windows regarding UTF-8 characters identical to MSVC.
Environment:
  • Windows 10 x64,
  • IPSXE 2017 Update 2,
  • VS 2015 Update 3,
  • Windows SDK 10.0.14393.33,
  • MSYS2 20161025,
  • ICU4C 59.1.
Alexander
Judith_W_Intel
thank for reporting this.
I have submitted cmplrs-43403 to hook up the /utf-8 switch to the necessary front end support.
In the meantime you should be able to use the following:
   -Qoption,cpp,--unicode_source_kind,"UTF-8"
Judith_W_Intel
I don't know what ICU4C on Windows is but using "icl" on Windows when the reference compiler is MSVC++ 2015 should enable utf8 character literals by default, i.e.:
128% cat utf8.cpp
int main() {
 char c = 'a';
 if (c == u'a');
 return 0;
129% icl -c utf8.cpp
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0 Beta Build x
Built Apr  5 2017 13:14:29 by jward4 on JWARD4-DESK1 in D:/workspaces/17_0cfe/dev
Copyright (C) 1985-2017 Intel Corporation.  All rights reserved.
utf8.cpp
130%
Can you attach your code so we can take a look? You said it only compiles with MSVC++ 2015 if you add the /utf-8 option, right?
You are right we should add the Microsoft /utf-8 option.
thanks
Judy
sav
Thank you for a quick response. Added "ICU4C" code to your test:
int main() {
    char c = u'•';
    return 0;
and reproduced error using ICC and MSVC:
c:\TEST>icl -c utf8.cpp
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0 Build 20170105
utf8.cpp
utf8.cpp(2): error: too many characters in character constant
      char c = u'???';
compilation aborted for utf8.cpp (code 2)
c:\TEST>icl -c -Qoption,cpp,"--uliterals" utf8.cpp
utf8.cpp
      char c = u'???';
c:\TEST>cl -c utf8.cpp
Microsoft (R) C/C++ Optimizing Compiler Version 19.00.24210 for x64
Copyright (C) Microsoft Corporation.  All rights reserved.
utf8.cpp
utf8.cpp(2): error C2015: too many characters in constant
c:\TEST>cl -c -utf-8 utf8.cpp
utf8.cpp
c:\TEST>
Test was successfully built using MSVC after adding '-utf-8' option to build command.
Alexander
Judith_W_Intel
sav
Thank you. The only flaw left, that special utf-8 character '•' is displayed incorrectly in ICC output to console:
c:\TEST>icl -c -Qoption,cpp,--unicode_source_kind,"UTF-8" utf8.cpp
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0.4.210 Build 20170411
utf8.cpp
utf8.cpp(2): warning #69: integer conversion resulted in truncation
      char c = u'???';
Though Windows console display special utf-8 characters correctly:
c:\TEST>echo '•'
Alexander
Yang__Richard
So the /utf-8 option still isn't available on icl, right? I'm still getting
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.0.4.245 Build 20190417
Copyright (C) 1985-2019 Intel Corporation.  All rights reserved.
