When enabling the intel compiler (downloaded trial version) integration into Visual Studio 2003 (Visual C++ Basic version), when opening the solution devstudio complains : "application for is not installed".
I know about the options that the intel compiler is not able to handle and basically use default settings. So is there an incompatibility between intel 7.1 and .Net 2003 ?
When disabling the integration, all works fine again.
You are probably using .NET 2003 Standard. You must use Professional or above. I had the same problem.
I figured that might be it.
toon
toon
