There appears to be a bug with inline variable initialization. The following code prints "0". With gcc, it prints "1".
(ICC) 19.0.0.117 20180804
#include <iostream>
int flag = 0;
class C
public:
C() { ::flag = 1; }
class D
public:
static inline C c = C();
int main(int, char **)
D d;
std::cout << ::flag << std::endl;
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
This may be a case of vendor dependent behavior between the order of a static constructor and global variable initialization.
Jim Dempsey
Thanks, but the behavior is the same if you assert() or throw() in the constructor. The constructor does not get called at all...ever.
Those may be determined at compile time.
Copy the last statement of main, and insert into first statement of the ctor and see what happens.
Strange. If you put the iostream operation in there, it gets run, but if you put throw(0) in the constructor, it doesn't get run...using icpc.
class C
public:
C() { throw(0); }
class D
public:
D d;
More to the point, this core dumps with a floating point exception, because the unordered_map ctor doesn't get run. This is how I found the problem:
#include <unordered_map>
class C
public:
C() { m.find(0); }
static inline std::unordered_map<int,int> m;
C c;
return 0;
