I try to test if packages will continue function with this new distro. I had installed Parallel Studio XE 2016 update 4 (even though it is unsupported OS). Found it did not cooperate with gcc 7.3, and that latest version 2018 update 1 is needed. So I attempt to install the C++ compiler.
If complains about pre-requisites:
32-bit libraries not found on this system.
This product release requires the presence of 32-bit compatibility libraries
when running on Intel(R) 64 architecture systems. One or more of these libraries
could not be found:
libstdc++ (including libstdc++6)
glibc
libgcc
I checked, and I had the 32-bit glibc and libgcc. So I installed 32-bit libstdc++ and started the install.sh again.
Unfortuately, it blocks with the same error.
Has anybody installed version 2018 on Leap 15?
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
