I am trying to install the 64-bit compiler (l_cproc_p_11.1.069_intel64) and having a dependency problem in step 4:
The following required for installation commands are missing:
libstdc++.so.5 (library)
libstdc++.so.5 does in fact exist on the system in both /usr/lib32 and /usr/lib64. /usr/lib is symbolicly linked to /usr/lib64. ldconfig shows the following:
$ /sbin/ldconfig -p | grep libstdc++.so.5libstdc++.so.5 (libc6,x86-64) => /usr/lib/libstdc++.so.5
libstdc++.so.5 (libc6) => /usr/lib32/libstdc++.so.5
libstdc++.so.5 (libc6) => /usr/lib32/libstdc++-v3/libstdc++.so.5
The following describes the system:
$ uname -s
Linux
$ uname -r
2.6.32-gentoo
$ uname -m
x86_64
$ uname -p
Intel Xeon CPU X5570 @ 2.93GHz
There are similar posts, but I believe all were actually missing the library. Any suggestion would be greatly appreciated.
Hi jamesg....
I don't have an answer to your problem... jsut wanted to post my problem in your thread since seems to be related and maybe someone can give us a common solution.
I just upgraded my Ubuntu to Karmic Koala (9.10) and installed l_cproc_p_11.1.069_ia32 !!! NOTE -> ia32!!!
everything went really smoothly but but when trying to compile a simple helloWorld.cpp I got:
.../11.1/069/bin/ia32/mcpcom: error while loading shared libraries: libstdc++.so.5: cannot open shared object file: No such file or directory
compilation aborted for hello.cpp (code 127)
I do have libstdc++.so.6 but NOT libstdc++.so.5 however it seems that the latter is an obsolete library and it's not coming with Ubuntu any longer.
What would be the right step to take???
Thanks for the reply. Were you having the same problem that I am having - with the installation, or was yours a case like apollo74 where libstdc++5 was missing altogether and caused the compiler to fail?
What version of libstdc++5 do you have installed. I have libstdc++.so.5.0.7 installed and the installation of the C compiler still fails as outlined above.
Hope that helps,
Peter
