Intel® C++ Compiler
intel C++ in windows / linux on a socket.c file...
krishna_m_
Hi all
in Linux, with ICC (16.0.3 on IA-32) I can compile a socket.c file and hence I can make a .a file
which contains the following C program (see below for <socket.c>)
But in WINDOWS [7] version of ICL (16.0.3) I couldnt successfully compile it....
(I tried added such as ...
#ifdef WIN32
   #include "winsock.h"
   #include "winsock2.h"
   #include <windows.h>
#else
   #include <sys/socket.h>
   #include <sys/un.h>
#endif
  etc. but no use of it ....)
Here I need an advice - how I can I compile this file in Windows using ICL (intels C) compiler ?
I really need this file to make a porting job  - which port a linux application into Windows. Please also note that
The same file is compiled in GCC of Cygwin in windows without any trouble !
Haopy some can help me
With best regards
Krishna mohan
/* A minimal wrapper for socket communication.
Copyright (C) 2013, Joshua More and Michele Ceriotti
Copyright (C) 2016, Bálint Aradi (adapted to F2003 C-bindings)
Functions:
   error: Prints an error message and then exits.
   open_socket_: Opens a socket with the required host server, socket type and
      port number.
   write_buffer_: Writes a string to the socket.
   read_buffer_: Reads data from the socket.
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <sys/types.h>
#include <netinet/in.h>
#include <sys/un.h>
#include <netdb.h>
void connect_inet_socket(int *psockfd, const char* host, int port)
/* Opens an internet socket.
   Note that fortran passes an extra argument for the string length,
   but this is ignored here for C compatibility.
   Args:
   psockfd: The id of the socket that will be created.
   port: The port number for the socket to be created. Low numbers are
         often reserved for important channels, so use of numbers of 4
         or more digits is recommended.
   host: The name of the host server.
  int sockfd, ai_err;
  // creates an internet socket
  // fetches information on the host
  struct addrinfo hints, *res;
  char service[256];
  memset(&hints, 0, sizeof(hints));
  hints.ai_socktype = SOCK_STREAM;
  hints.ai_family = AF_UNSPEC;
  hints.ai_flags = AI_PASSIVE;
  sprintf(service, "%d", port); // convert the port number to a string
  ai_err = getaddrinfo(host, service, &hints, &res);
  if (ai_err!=0) {
    printf("Error code: %i\n",ai_err);
    perror("Error fetching host data. Wrong host name?");
    exit(-1);
  // creates socket
  sockfd = socket(res->ai_family, res->ai_socktype, res->ai_protocol);
  if (sockfd < 0) {
    perror("Error opening socket");
    exit(-1);
  // makes connection
  if (connect(sockfd, res->ai_addr, res->ai_addrlen) < 0) {
    perror("Error opening INET socket: wrong port or server unreachable");
    exit(-1);
  freeaddrinfo(res);
  *psockfd = sockfd;
void connect_unix_socket(int *psockfd, const char* pathname)
/* Opens a unix socket.
   Args:
   pathname: The name of the file to use for sun_path.
  int sockfd, ai_err;
  struct sockaddr_un serv_addr;
  printf("Connecting to :%s:\n",pathname);
  // fills up details of the socket addres
  memset(&serv_addr, 0, sizeof(serv_addr));
  serv_addr.sun_family = AF_UNIX;
  /* Beware of buffer over runs
     UNIX Network Programming by Richard Stevens mentions
     that the use of sizeof() is ok, but see
     http://mail-index.netbsd.org/tech-net/2006/10/11/0008.html
  if ((int)strlen(pathname)> sizeof(serv_addr.sun_path)) {
    perror("Error opening UNIX socket: pathname too long\n");
    exit(-1);
  } else {
    strcpy(serv_addr.sun_path, pathname);
  // creates a unix socket
  // creates the socket
  sockfd = socket(AF_UNIX, SOCK_STREAM, 0);
  // connects
  if (connect(sockfd, (struct sockaddr *) &serv_addr, sizeof(serv_addr)) < 0) {
    perror("Error opening UNIX socket: path unavailable, or already existing");
    exit(-1);
  *psockfd = sockfd;
void writebuffer_socket(int sockfd, const void *data, int len)
/* Writes to a socket.
Args:
   sockfd: The id of the socket that will be written to.
   data: The data to be written to the socket.
   len: The length of the data in bytes.
   int n;
   n = write(sockfd, (char *) data, len);
   if (n < 0) {
     perror("Error writing to socket: server has quit or connection broke");
     exit(-1);
void readbuffer_socket(int sockfd, void *data, int len)
/* Reads from a socket.
Args:
   sockfd: The id of the socket that will be read from.
   data: The storage array for data read from the socket.
   int n, nr;
   char *pdata;
   pdata = (char *) data;
   n = nr = read(sockfd, pdata, len);
   while (nr > 0 && n < len) {
     nr = read(sockfd, &(pdata), len - n);
     n += nr;
   if (n == 0) {
     perror("Error reading from socket: server has quit or connection broke");
     exit(-1);
void shutdown_socket(int sockfd)
/* Shuts down the socket.
  shutdown(sockfd, 2);
  close(sockfd);
Varsha_M_Intel
Hi ,
What is the error you are getting? What version of Visual Studio are you using? Could you provide the options to compile your program?
Varsha
krishna_m_
Hi
thanks for the reply.
I use Ifort 2016.3.207, Windows 7, and Cygwin GCC 4.6.3. Currently I am not using MSVS.
Please note that I use Cygwin to run the make etc.
As I said, I am trying to port a software for windows which use socket.c and fsockets.f90 in linux (and in Linux I can GCC for socket.c without any trouble... )
Pleas see the attachment for fsocket.f90 in below portion.
I noted :
(1) In Linux I can see NO Leading or trailing underscore, but in windows gcc produce leading underscore:
(2) In Windows, A completely inverted Uppercase letters is included in .o fortran file
(eg. _F90SOCKETS_mp_CONNECT_INET_SOCKET instead of f90sockets_MP_connect_unix_socket_ ) and its underscore
is Leading not trailing.
with $ nm libfsockets.a (which is produced by: ar rcs libfsockets.a sockets.o fsockets.o ),
IN LINUX
sockets.o:
         U close
         U connect
00000000 T connect_inet_socket
00000140 T connect_unix_socket
         U exit
         U freeaddrinfo
fsockets.o:
         U connect_inet_socket
         U connect_unix_socket
00000000 T f90sockets._
00000010 T f90sockets_MP_connect_inet_socket_
000000e0 T f90sockets_MP_connect_unix_socket_
000005c0 T f90sockets_MP_readbuffer_d_
______________________________________________________
in Windows (ifort (fsockets.o) GCC(sockets.c) version)
sockets.o:
         U _close
         U _connect
00000000 T _connect_inet_socket
00000141 T _connect_unix_socket
         U _exit
         U _connect_inet_socket
         U _connect_unix_socket
00000000 T _F90SOCKETS.
00000010 T _F90SOCKETS_mp_CONNECT_INET_SOCKET
000000e0 T _F90SOCKETS_mp_CONNECT_UNIX_SOCKET
000005d0 T _F90SOCKETS_mp_READBUFFER_D
000006f0 T _F90SOCKETS_mp_READBUFFER_DV
(3) Using cygwins GCC/gfortran I could compile these ...
My options are:
# Options for the Fortran compiler
FXXOPT = -O2 -qopenmp -openmp /Qopenmp -ip -standard-semantics -xW -fpp  (for ifort)
CCOPT  = -O2 -ip                                                          (for gcc  )
Hope you can make some suggestions - at least how to adjust trailing/leading underscores and to convert _F90SOCKETS_mp_CONNECT_UNIX_SOCKET (etc ) to f90sockets_MP_connect_unix_socket_ which may solve the issue I guess...
Krishna mohan G P
! f90sockets.f90 is following .............................................................
module f90sockets
  use iso_c_binding
  implicit none
  private
  public :: connect_inet_socket, connect_unix_socket, readbuffer, writebuffer, shutdown_socket
  interface writebuffer
    module procedure writebuffer_s, writebuffer_d, writebuffer_dv, writebuffer_i
  end interface writebuffer
  interface readbuffer
    module procedure readbuffer_s
    module procedure readbuffer_dv
    module procedure readbuffer_i
  end interface readbuffer
  ! interface bindings for c routines
  interface
    subroutine connect_inet_socket_c(sockfd, host, port) bind(C, name='connect_inet_socket')
      import :: c_int, c_char
      integer(c_int), intent(out) :: sockfd
      character(kind=c_char), dimension(*), intent(in) :: host
      integer(c_int), value, intent(in) :: port
    end subroutine connect_inet_socket_c
    subroutine connect_unix_socket_c(sockfd, host) bind(C, name='connect_unix_socket')
    end subroutine connect_unix_socket_c
    subroutine writebuffer_socket_c(sockfd, data, len) bind(C, name='writebuffer_socket')
      import :: c_int, c_ptr
      integer(c_int), value, intent(in) :: sockfd
      type(c_ptr), value, intent(in) :: data
      integer(c_int), value :: len
    end subroutine writebuffer_socket_c
    subroutine readbuffer_socket_c(sockfd, data, len) bind(C, name='readbuffer_socket')
      integer(c_int), value, intent(in) :: len
    end subroutine readbuffer_socket_c
    subroutine shutdown_socket_c(sockfd) bind(C, name='shutdown_socket')
      import :: c_int
    end subroutine shutdown_socket_c
  end interface
contains
  ! Internet socket
  subroutine connect_inet_socket(sockfd, host, port)
    character(kind=c_char, len=*), intent(in) :: host
    integer(c_int), intent(in) :: port
    call connect_inet_socket_c(sockfd, trim(host) // c_null_char, port)
  ! Unix socket
  subroutine connect_unix_socket(sockfd, host)
    call connect_unix_socket_c(sockfd, trim(host) // c_null_char)
  ! Close the socket
  subroutine shutdown_socket(sockfd)
    integer(c_int), intent(in) :: sockfd
    call shutdown_socket_c(sockfd)
  ! write a float (real)
  subroutine writebuffer_d(sockfd, fdata)
    real(c_double), target, intent(in) :: fdata
    call writebuffer_socket_c(sockfd, c_loc(fdata), 8_c_int)
  end subroutine writebuffer_d
  ! Write an integer
  subroutine writebuffer_i(sockfd, fdata)
    integer(c_int), target, intent(in) :: fdata
    call writebuffer_socket_c(sockfd, c_loc(fdata), 4_c_int)
  end subroutine writebuffer_i
  ! write a string
  subroutine writebuffer_s(sockfd, fstring)
    character(kind=c_char, len=*), intent(in) :: fstring
    character(kind=c_char), target :: cstring(len(fstring))
    integer :: trimlen
    cstring(:) = transfer(fstring, cstring)
    trimlen = len_trim(fstring)
    cstring(trimlen + 1:) = ' '
    call writebuffer_socket_c(sockfd, c_loc(cstring), size(cstring, kind=c_int))
  subroutine writebuffer_dv(sockfd, fdata)
    real(c_double), target, intent(in) :: fdata(:)
    call writebuffer_socket_c(sockfd, c_loc(fdata), 8_c_int * size(fdata, kind=c_int))
  end subroutine writebuffer_dv
  subroutine readbuffer_d(sockfd, fdata)
    real(c_double), target, intent(out) :: fdata
    call readbuffer_socket_c(sockfd, c_loc(fdata), 8_c_int)
  end subroutine readbuffer_d
  subroutine readbuffer_i(sockfd, fdata)
    integer(c_int), target, intent(out) :: fdata
    call readbuffer_socket_c(sockfd, c_loc(fdata), 4_c_int)
  end subroutine readbuffer_i
  subroutine readbuffer_s(sockfd, fstring)
    character(kind=c_char, len=*), intent(out) :: fstring
    integer :: ii
    call readbuffer_socket_c(sockfd, c_loc(cstring), size(cstring, kind=c_int))
    fstring = ""
    do ii = 1, size(cstring)
      if (cstring(ii) == c_null_char) then
        exit
      end if
      fstring(ii:ii) = cstring(ii)
    end do
  subroutine readbuffer_dv(sockfd, fdata)
    real(c_double), target, intent(out) :: fdata(:)
    call readbuffer_socket_c(sockfd, c_loc(fdata), 8_c_int * size(fdata, kind=c_int))
  end subroutine readbuffer_dv
end module f90sockets
SergeyKostrov
Valued Contributor II
Krishna, I'll do a very short follow up on your Post #1: 1. There are no any problems with Intel C++ compiler 2. You need to re-implement, or port, a function with connect functionality 3. If you really want to get as better as possible experience I recommend you look for POSIX Man Pages for UNIX/LINUX OSs, and MSDN for Windows OSs 4. In case of Windows any version of Microsoft Platform SDK has lots of examples on how sockets should be used in Windows OSs 5. An example on how you should do it will be posted. Once again, this is not a problem with Intel C++ compiler and you need to do the job if this is your job or student assignment.
SergeyKostrov
Functions:
      port number.
- 02.02.2017: Sergey Kostrov's ( SK ) notes:
 - https://software.intel.com/en-us/forums/intel-c-compiler/topic/710141
 - For compilation with Intel C++ compiler for Windows without linking use
   icl.exe -c <filename>
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
// SK
#ifdef _WIN32
 #include <winsock2.h>
 #include <ws2tcpip.h>
#else
 #include <sys/un.h>
 #include <netdb.h>
#endif
// SK
void connect_inet_socket( int *psockfd, const char* host, int port );
#ifdef _WIN32
void connect_windows_socket( int *psockfd, const char* pathname );
#else
void connect_unix_socket( int *psockfd, const char* pathname );
#endif
void writebuffer_socket( int sockfd, const void *data, int len );
void readbuffer_socket( int sockfd, void *data, int len );
void shutdown_socket( int sockfd );
// SK
/* Access to sockets needs to be done with a wrapper function 'connect_socket'
   and it is substituted by 'connect_windows_socket' or by 'connect_unix_socket'
   ( depends on a state of the macro _WIN32 ) during preprocessing phase of
   the compilation.
   For portability 'connect_windows_socket' and 'connect_unix_socket' shouldn't
   be used directly and the wrapper function 'connect_socket' must be used instead.
#ifdef _WIN32
 #define connect_socket   connect_windows_socket
#else
 #define connect_socket   connect_unix_socket
#endif
   Args:
  int sockfd, ai_err;
  char service[256];
  if (ai_err!=0) {
    exit(-1);
  // creates socket
  if (sockfd < 0) {
    exit(-1);
  // makes connection
    exit(-1);
  freeaddrinfo(res);
  *psockfd = sockfd;
// SK
/* Opens a socket.
   Args:
#ifdef _WIN32
  // Required functionality for Windows
#else
  // Required functionality for Unix
  int sockfd, ai_err;
  struct sockaddr_in serv_addr;
    exit(-1);
  } else {
  // connects
    exit(-1);
  *psockfd = sockfd;
#endif
Args:
   int n;
   if (n < 0) {
     exit(-1);
Args:
   int n, nr;
   char *pdata;
     n += nr;
   if (n == 0) {
     exit(-1);
  shutdown( sockfd, 2 );
  close( sockfd );
SergeyKostrov
Source file attached as well.
krishna_m_
dear Sergey,
Many thanks for the infos (actually it was not a job/assignment work, it is a voluntary  source  contribution to a publicly available science package...)
I have ran your files and I think need to edit the F90 file for the windows. I will let you know the progress
cheers
krishna
