Hi all
in Linux, with ICC (16.0.3 on IA-32) I can compile a socket.c file and hence I can make a .a file
which contains the following C program (see below for <socket.c>)
But in WINDOWS [7] version of ICL (16.0.3) I couldnt successfully compile it....
(I tried added such as ...
#ifdef WIN32
#include "winsock.h"
#include "winsock2.h"
#include <windows.h>
#else
#include <sys/socket.h>
#include <sys/un.h>
#endif
etc. but no use of it ....)
Here I need an advice - how I can I compile this file in Windows using ICL (intels C) compiler ?
I really need this file to make a porting job - which port a linux application into Windows. Please also note that
The same file is compiled in GCC of Cygwin in windows without any trouble !
Haopy some can help me
With best regards
Krishna mohan
/* A minimal wrapper for socket communication. Copyright (C) 2013, Joshua More and Michele Ceriotti Copyright (C) 2016, Bálint Aradi (adapted to F2003 C-bindings) ... Functions: error: Prints an error message and then exits. open_socket_: Opens a socket with the required host server, socket type and port number. write_buffer_: Writes a string to the socket. read_buffer_: Reads data from the socket. */ #include <stdio.h> #include <stdlib.h> #include <unistd.h> #include <string.h> #include <sys/types.h> #include <sys/socket.h> #include <netinet/in.h> #include <sys/un.h> #include <netdb.h> void connect_inet_socket(int *psockfd, const char* host, int port) /* Opens an internet socket. Note that fortran passes an extra argument for the string length, but this is ignored here for C compatibility. Args: psockfd: The id of the socket that will be created. port: The port number for the socket to be created. Low numbers are often reserved for important channels, so use of numbers of 4 or more digits is recommended. host: The name of the host server. */ { int sockfd, ai_err; // creates an internet socket // fetches information on the host struct addrinfo hints, *res; char service[256]; memset(&hints, 0, sizeof(hints)); hints.ai_socktype = SOCK_STREAM; hints.ai_family = AF_UNSPEC; hints.ai_flags = AI_PASSIVE; sprintf(service, "%d", port); // convert the port number to a string ai_err = getaddrinfo(host, service, &hints, &res); if (ai_err!=0) { printf("Error code: %i\n",ai_err); perror("Error fetching host data. Wrong host name?"); exit(-1); } // creates socket sockfd = socket(res->ai_family, res->ai_socktype, res->ai_protocol); if (sockfd < 0) { perror("Error opening socket"); exit(-1); } // makes connection if (connect(sockfd, res->ai_addr, res->ai_addrlen) < 0) { perror("Error opening INET socket: wrong port or server unreachable"); exit(-1); } freeaddrinfo(res); *psockfd = sockfd; } void connect_unix_socket(int *psockfd, const char* pathname) /* Opens a unix socket. Note that fortran passes an extra argument for the string length, but this is ignored here for C compatibility. Args: psockfd: The id of the socket that will be created. pathname: The name of the file to use for sun_path. */ { int sockfd, ai_err; struct sockaddr_un serv_addr; printf("Connecting to :%s:\n",pathname); // fills up details of the socket addres memset(&serv_addr, 0, sizeof(serv_addr)); serv_addr.sun_family = AF_UNIX; /* Beware of buffer over runs UNIX Network Programming by Richard Stevens mentions that the use of sizeof() is ok, but see http://mail-index.netbsd.org/tech-net/2006/10/11/0008.html */ if ((int)strlen(pathname)> sizeof(serv_addr.sun_path)) { perror("Error opening UNIX socket: pathname too long\n"); exit(-1); } else { strcpy(serv_addr.sun_path, pathname); } // creates a unix socket // creates the socket sockfd = socket(AF_UNIX, SOCK_STREAM, 0); // connects if (connect(sockfd, (struct sockaddr *) &serv_addr, sizeof(serv_addr)) < 0) { perror("Error opening UNIX socket: path unavailable, or already existing"); exit(-1); } *psockfd = sockfd; } void writebuffer_socket(int sockfd, const void *data, int len) /* Writes to a socket. Args: sockfd: The id of the socket that will be written to. data: The data to be written to the socket. len: The length of the data in bytes. */ { int n; n = write(sockfd, (char *) data, len); if (n < 0) { perror("Error writing to socket: server has quit or connection broke"); exit(-1); } } void readbuffer_socket(int sockfd, void *data, int len) /* Reads from a socket. Args: sockfd: The id of the socket that will be read from. data: The storage array for data read from the socket. len: The length of the data in bytes. */ { int n, nr; char *pdata; pdata = (char *) data; n = nr = read(sockfd, pdata, len); while (nr > 0 && n < len) { nr = read(sockfd, &(pdata), len - n); n += nr; } if (n == 0) { perror("Error reading from socket: server has quit or connection broke"); exit(-1); } } void shutdown_socket(int sockfd) /* Shuts down the socket. */ { shutdown(sockfd, 2); close(sockfd); }
Hi ,
What is the error you are getting? What version of Visual Studio are you using? Could you provide the options to compile your program?
Varsha
Hi
thanks for the reply.
I use Ifort 2016.3.207, Windows 7, and Cygwin GCC 4.6.3. Currently I am not using MSVS.
Please note that I use Cygwin to run the make etc.
As I said, I am trying to port a software for windows which use socket.c and fsockets.f90 in linux (and in Linux I can GCC for socket.c without any trouble... )
Pleas see the attachment for fsocket.f90 in below portion.
I noted :
(1) In Linux I can see NO Leading or trailing underscore, but in windows gcc produce leading underscore:
(2) In Windows, A completely inverted Uppercase letters is included in .o fortran file
(eg. _F90SOCKETS_mp_CONNECT_INET_SOCKET instead of f90sockets_MP_connect_unix_socket_ ) and its underscore
is Leading not trailing.
with $ nm libfsockets.a (which is produced by: ar rcs libfsockets.a sockets.o fsockets.o ),
IN LINUX
sockets.o:
U close
U connect
00000000 T connect_inet_socket
00000140 T connect_unix_socket
U exit
U freeaddrinfo
fsockets.o:
U connect_inet_socket
U connect_unix_socket
00000000 T f90sockets._
00000010 T f90sockets_MP_connect_inet_socket_
000000e0 T f90sockets_MP_connect_unix_socket_
000005c0 T f90sockets_MP_readbuffer_d_
______________________________________________________
in Windows (ifort (fsockets.o) GCC(sockets.c) version)
sockets.o:
U _close
U _connect
00000000 T _connect_inet_socket
00000141 T _connect_unix_socket
U _exit
U _connect_inet_socket
U _connect_unix_socket
00000000 T _F90SOCKETS.
00000010 T _F90SOCKETS_mp_CONNECT_INET_SOCKET
000000e0 T _F90SOCKETS_mp_CONNECT_UNIX_SOCKET
000005d0 T _F90SOCKETS_mp_READBUFFER_D
000006f0 T _F90SOCKETS_mp_READBUFFER_DV
(3) Using cygwins GCC/gfortran I could compile these ...
My options are:
# Options for the Fortran compiler
FXXOPT = -O2 -qopenmp -openmp /Qopenmp -ip -standard-semantics -xW -fpp (for ifort)
CCOPT = -O2 -ip (for gcc )
Hope you can make some suggestions - at least how to adjust trailing/leading underscores and to convert _F90SOCKETS_mp_CONNECT_UNIX_SOCKET (etc ) to f90sockets_MP_connect_unix_socket_ which may solve the issue I guess...
Krishna mohan G P
! f90sockets.f90 is following .............................................................
module f90sockets use iso_c_binding implicit none private public :: connect_inet_socket, connect_unix_socket, readbuffer, writebuffer, shutdown_socket interface writebuffer module procedure writebuffer_s, writebuffer_d, writebuffer_dv, writebuffer_i end interface writebuffer interface readbuffer module procedure readbuffer_s module procedure readbuffer_dv module procedure readbuffer_d module procedure readbuffer_i end interface readbuffer ! interface bindings for c routines interface subroutine connect_inet_socket_c(sockfd, host, port) bind(C, name='connect_inet_socket') import :: c_int, c_char integer(c_int), intent(out) :: sockfd character(kind=c_char), dimension(*), intent(in) :: host integer(c_int), value, intent(in) :: port end subroutine connect_inet_socket_c subroutine connect_unix_socket_c(sockfd, host) bind(C, name='connect_unix_socket') import :: c_int, c_char integer(c_int), intent(out) :: sockfd character(kind=c_char), dimension(*), intent(in) :: host end subroutine connect_unix_socket_c subroutine writebuffer_socket_c(sockfd, data, len) bind(C, name='writebuffer_socket') import :: c_int, c_ptr integer(c_int), value, intent(in) :: sockfd type(c_ptr), value, intent(in) :: data integer(c_int), value :: len end subroutine writebuffer_socket_c subroutine readbuffer_socket_c(sockfd, data, len) bind(C, name='readbuffer_socket') import :: c_int, c_ptr integer(c_int), value, intent(in) :: sockfd type(c_ptr), value, intent(in) :: data integer(c_int), value, intent(in) :: len end subroutine readbuffer_socket_c subroutine shutdown_socket_c(sockfd) bind(C, name='shutdown_socket') import :: c_int integer(c_int), value, intent(in) :: sockfd end subroutine shutdown_socket_c end interface contains ! Internet socket subroutine connect_inet_socket(sockfd, host, port) integer(c_int), intent(out) :: sockfd character(kind=c_char, len=*), intent(in) :: host integer(c_int), intent(in) :: port call connect_inet_socket_c(sockfd, trim(host) // c_null_char, port) end subroutine connect_inet_socket ! Unix socket subroutine connect_unix_socket(sockfd, host) integer(c_int), intent(out) :: sockfd character(kind=c_char, len=*), intent(in) :: host call connect_unix_socket_c(sockfd, trim(host) // c_null_char) end subroutine connect_unix_socket ! Close the socket subroutine shutdown_socket(sockfd) integer(c_int), intent(in) :: sockfd call shutdown_socket_c(sockfd) end subroutine shutdown_socket ! write a float (real) subroutine writebuffer_d(sockfd, fdata) integer(c_int), intent(in) :: sockfd real(c_double), target, intent(in) :: fdata call writebuffer_socket_c(sockfd, c_loc(fdata), 8_c_int) end subroutine writebuffer_d ! Write an integer subroutine writebuffer_i(sockfd, fdata) integer(c_int), intent(in) :: sockfd integer(c_int), target, intent(in) :: fdata call writebuffer_socket_c(sockfd, c_loc(fdata), 4_c_int) end subroutine writebuffer_i ! write a string subroutine writebuffer_s(sockfd, fstring) integer(c_int), intent(in) :: sockfd character(kind=c_char, len=*), intent(in) :: fstring character(kind=c_char), target :: cstring(len(fstring)) integer :: trimlen cstring(:) = transfer(fstring, cstring) trimlen = len_trim(fstring) cstring(trimlen + 1:) = ' ' call writebuffer_socket_c(sockfd, c_loc(cstring), size(cstring, kind=c_int)) end subroutine writebuffer_s subroutine writebuffer_dv(sockfd, fdata) integer(c_int), intent(in) :: sockfd real(c_double), target, intent(in) :: fdata(:) call writebuffer_socket_c(sockfd, c_loc(fdata), 8_c_int * size(fdata, kind=c_int)) end subroutine writebuffer_dv subroutine readbuffer_d(sockfd, fdata) integer(c_int), intent(in) :: sockfd real(c_double), target, intent(out) :: fdata call readbuffer_socket_c(sockfd, c_loc(fdata), 8_c_int) end subroutine readbuffer_d subroutine readbuffer_i(sockfd, fdata) integer(c_int), intent(in) :: sockfd integer(c_int), target, intent(out) :: fdata call readbuffer_socket_c(sockfd, c_loc(fdata), 4_c_int) end subroutine readbuffer_i subroutine readbuffer_s(sockfd, fstring) integer(c_int), intent(in) :: sockfd character(kind=c_char, len=*), intent(out) :: fstring character(kind=c_char), target :: cstring(len(fstring)) integer :: ii call readbuffer_socket_c(sockfd, c_loc(cstring), size(cstring, kind=c_int)) fstring = "" do ii = 1, size(cstring) if (cstring(ii) == c_null_char) then exit end if fstring(ii:ii) = cstring(ii) end do end subroutine readbuffer_s subroutine readbuffer_dv(sockfd, fdata) integer(c_int), intent(in) :: sockfd real(c_double), target, intent(out) :: fdata(:) call readbuffer_socket_c(sockfd, c_loc(fdata), 8_c_int * size(fdata, kind=c_int)) end subroutine readbuffer_dv end module f90sockets
/////////////////////////////////////////////////////////////////////////////// /* A minimal wrapper for socket communication. Copyright (C) 2013, Joshua More and Michele Ceriotti Copyright (C) 2016, Bálint Aradi (adapted to F2003 C-bindings) Functions: error: Prints an error message and then exits. open_socket_: Opens a socket with the required host server, socket type and port number. write_buffer_: Writes a string to the socket. read_buffer_: Reads data from the socket. - 02.02.2017: Sergey Kostrov's ( SK ) notes: - https://software.intel.com/en-us/forums/intel-c-compiler/topic/710141 - For compilation with Intel C++ compiler for Windows without linking use icl.exe -c <filename> */ /////////////////////////////////////////////////////////////////////////////// #include <stdio.h> #include <stdlib.h> #include <unistd.h> #include <string.h> #include <sys/types.h> /////////////////////////////////////////////////////////////////////////////// // SK #ifdef _WIN32 #include <winsock2.h> #include <ws2tcpip.h> #else #include <sys/socket.h> #include <netinet/in.h> #include <sys/un.h> #include <netdb.h> #endif /////////////////////////////////////////////////////////////////////////////// // SK void connect_inet_socket( int *psockfd, const char* host, int port ); #ifdef _WIN32 void connect_windows_socket( int *psockfd, const char* pathname ); #else void connect_unix_socket( int *psockfd, const char* pathname ); #endif void writebuffer_socket( int sockfd, const void *data, int len ); void readbuffer_socket( int sockfd, void *data, int len ); void shutdown_socket( int sockfd ); /////////////////////////////////////////////////////////////////////////////// // SK /* Access to sockets needs to be done with a wrapper function 'connect_socket' and it is substituted by 'connect_windows_socket' or by 'connect_unix_socket' ( depends on a state of the macro _WIN32 ) during preprocessing phase of the compilation. For portability 'connect_windows_socket' and 'connect_unix_socket' shouldn't be used directly and the wrapper function 'connect_socket' must be used instead. */ #ifdef _WIN32 #define connect_socket connect_windows_socket #else #define connect_socket connect_unix_socket #endif /////////////////////////////////////////////////////////////////////////////// /* Opens an internet socket. Note that fortran passes an extra argument for the string length, but this is ignored here for C compatibility. Args: psockfd: The id of the socket that will be created. port: The port number for the socket to be created. Low numbers are often reserved for important channels, so use of numbers of 4 or more digits is recommended. host: The name of the host server. */ void connect_inet_socket( int *psockfd, const char* host, int port ) { int sockfd, ai_err; // creates an internet socket // fetches information on the host struct addrinfo hints, *res; char service[256]; memset(&hints, 0, sizeof(hints)); hints.ai_socktype = SOCK_STREAM; hints.ai_family = AF_UNSPEC; hints.ai_flags = AI_PASSIVE; sprintf(service, "%d", port); // convert the port number to a string ai_err = getaddrinfo(host, service, &hints, &res); if (ai_err!=0) { printf("Error code: %i\n",ai_err); perror("Error fetching host data. Wrong host name?"); exit(-1); } // creates socket sockfd = socket(res->ai_family, res->ai_socktype, res->ai_protocol); if (sockfd < 0) { perror("Error opening socket"); exit(-1); } // makes connection if (connect(sockfd, res->ai_addr, res->ai_addrlen) < 0) { perror("Error opening INET socket: wrong port or server unreachable"); exit(-1); } freeaddrinfo(res); *psockfd = sockfd; } /////////////////////////////////////////////////////////////////////////////// // SK /* Opens a socket. Note that fortran passes an extra argument for the string length, but this is ignored here for C compatibility. Args: psockfd: The id of the socket that will be created. pathname: The name of the file to use for sun_path. */ #ifdef _WIN32 void connect_windows_socket( int *psockfd, const char* pathname ) { // Required functionality for Windows // ... } #else void connect_unix_socket( int *psockfd, const char* pathname ) { // Required functionality for Unix int sockfd, ai_err; struct sockaddr_in serv_addr; printf("Connecting to :%s:\n",pathname); // fills up details of the socket addres memset(&serv_addr, 0, sizeof(serv_addr)); serv_addr.sun_family = AF_UNIX; /* Beware of buffer over runs UNIX Network Programming by Richard Stevens mentions that the use of sizeof() is ok, but see http://mail-index.netbsd.org/tech-net/2006/10/11/0008.html */ if ((int)strlen(pathname)> sizeof(serv_addr.sun_path)) { perror("Error opening UNIX socket: pathname too long\n"); exit(-1); } else { strcpy(serv_addr.sun_path, pathname); } // creates a unix socket // creates the socket sockfd = socket(AF_UNIX, SOCK_STREAM, 0); // connects if (connect(sockfd, (struct sockaddr *) &serv_addr, sizeof(serv_addr)) < 0) { perror("Error opening UNIX socket: path unavailable, or already existing"); exit(-1); } *psockfd = sockfd; } #endif /////////////////////////////////////////////////////////////////////////////// /* Writes to a socket. Args: sockfd: The id of the socket that will be written to. data: The data to be written to the socket. len: The length of the data in bytes. */ void writebuffer_socket( int sockfd, const void *data, int len ) { int n; n = write(sockfd, (char *) data, len); if (n < 0) { perror("Error writing to socket: server has quit or connection broke"); exit(-1); } } /////////////////////////////////////////////////////////////////////////////// /* Reads from a socket. Args: sockfd: The id of the socket that will be read from. data: The storage array for data read from the socket. len: The length of the data in bytes. */ void readbuffer_socket( int sockfd, void *data, int len ) { int n, nr; char *pdata; pdata = (char *) data; n = nr = read(sockfd, pdata, len); while (nr > 0 && n < len) { nr = read(sockfd, &(pdata), len - n); n += nr; } if (n == 0) { perror("Error reading from socket: server has quit or connection broke"); exit(-1); } } /////////////////////////////////////////////////////////////////////////////// /* Shuts down the socket. */ void shutdown_socket( int sockfd ) { shutdown( sockfd, 2 ); close( sockfd ); }
dear Sergey,
Many thanks for the infos (actually it was not a job/assignment work, it is a voluntary source contribution to a publicly available science package...)
I have ran your files and I think need to edit the F90 file for the windows. I will let you know the progress
cheers
krishna
