Intel® C++ Compiler
7956 Discussions
intel c++9.0 for linux install problem
chbq
I have download the intel c++ 9.0 for linux,my system is fedora core 4,and i extract the ISO file ,the fellowing files are extract form the ISO file:
file:///usr/DownLoad/Intel/BEA_License_Agreement.txt
file:///usr/DownLoad/Intel/chklic.32
file:///usr/DownLoad/Intel/chklic.64
file:///usr/DownLoad/Intel/chklic.em64t
file:///usr/DownLoad/Intel/Disclaimer.txt
file:///usr/DownLoad/Intel/eclipse-platform-3.0.1-linux-gtk.zip
file:///usr/DownLoad/Intel/eclipse-platform-3.0.1-linux-motif.zip
file:///usr/DownLoad/Intel/EPCommonLauncher.sh
file:///usr/DownLoad/Intel/EPinstall.sh
file:///usr/DownLoad/Intel/EPSilentInstallConfigFile.ini
file:///usr/DownLoad/Intel/EPuninstall.sh
file:///usr/DownLoad/Intel/flex_ug.pdf
file:///usr/DownLoad/Intel/install_cc.sh
file:///usr/DownLoad/Intel/install.htm
file:///usr/DownLoad/Intel/install.sh
file:///usr/DownLoad/Intel/install.txt
file:///usr/DownLoad/Intel/intel-eidb9-9.0-035.ia64.rpm
file:///usr/DownLoad/Intel/intel-icc9-9.0-030.i386.rpm
file:///usr/DownLoad/Intel/intel-icc9-9.0-030.ia64.rpm
file:///usr/DownLoad/Intel/intel-icce9-9.0-030.em64t.rpm
file:///usr/DownLoad/Intel/intel-icc_ide9-9.0-030.i386.rpm
file:///usr/DownLoad/Intel/intel-iidb9-9.0-035.i386.rpm
file:///usr/DownLoad/Intel/intel-iidbe9-9.0-035.em64t.rpm
file:///usr/DownLoad/Intel/intel-isubh9-9.0-030.i386.rpm
file:///usr/DownLoad/Intel/intel-isubh9-9.0-030.ia64.rpm
file:///usr/DownLoad/Intel/intel-isubhe9-9.0-030.em64t.rpm
file:///usr/DownLoad/Intel/linux_ia32_jrockit150_jre.zip
file:///usr/DownLoad/Intel/org.eclipse.cdt-2.1.1-linux.x86.zip
file:///usr/DownLoad/Intel/readme.txt
file:///usr/DownLoad/Intel/ReleaseNotes.htm
file:///usr/DownLoad/Intel/ReleaseNotes.txt
file:///usr/DownLoad/Intel/sdp-core-2.0.2.zip
file:///usr/DownLoad/Intel/SilentInstallConfigFile.ini
file:///usr/DownLoad/Intel/SilentInstallFParser.awk
file:///usr/DownLoad/Intel/zwtiso.nfo
I fellow the steps as the installation guide: ./install.sh ... However,I am failed, the fellowing is the messages:
[root@localhost Intel]# ./install.sh
./install.sh: line 136: pushd: ./instman: No such file or directory
./install.sh: line 147: ./secore: No such file or directory
./install.sh: line 154: popd: directory stack empty
so I install the intel-isubh9-9.0-030.i386.rpm and intel-icc9-9.0-030.i386.rpm,the compiler also does not work.
I want to know how to install this compiler,please help me ,thank you !
TimP
Do you mean ISO? Assuming you unpacked the tar.gz file using tar or equivalent, it looks like you may have run out of disk space, or don't have permission for mkdir.
chbq
I have download another package of intel c++ for linux from the intel website,that is a tar.gz package,I fellow the steps and successfully installed the intel c++ for linux, However,I don't use that ISO package.
John_O_Intel
Glad you were able to install the compilers. One of the developers looked at this and reported the problem is you didn't seem to have the /instman directory, which could be due to running out of disk space or from accessing an incomplete compiler package.
regards,
_|ohnO
