Good morning,
I've triedto use the pre-defined macro _USE_INTEL_COMPILER (which worked pretty well in former versions of visual studio ) in my visual studio 2008 solution/project. Unfortunately I only found information about this macro for versions of VS up to 2005 where you can use it under project properties->C/C++ preprocessor settings. How does this macro work under VS2008? althoughI've definded the macro my VS2008 always uses the MS C++ Compiler instead of Intel's one.
mawo
This macros is for backwords compatibility. Its primary usage is within VC6 IDE.
For VC2003/2005/2008 projects, it's better to do it following way:
- On ToolsOption dialog, select "Intel C++"->"General", there's a check-box for "Override Intel C++ Compiler selection and user Visual C++ Compiler". check this box.
- use "ctrl+right-click" to select multiple projects you'd like to use Intel C++ Compiler to build some files.
- then click the "Use Intel C" icon: because of step1, all those projects will be still using Visual C++ compiler.
- then right click on the file/files you'd like IntelC to compile, select "Properties", and you can set the compiler to be IntelC.
If you need those two macros, let me find out why it doesn't work any more. Are you using the latest 10.1.022?
Maybe because I'm using 10.1.021 instead of 10.1.022?
I've solved the problem, thanks.
