Intel® C++ Compiler
7931 Discussions
intel compiler toolchain on CentOS - linking against custom glibc
krukov__ivan
Hello, all.
I am trying to get the the 2019 release working on centos6.
The system ships with gcc 4.4 and old glibc, which do not have full support for c++11. Instead, I compiled and installed gcc 5.5 and glibc 2.23 through linuxbrew, and I am trying to compile with `icpc` with linuxbrew's `gcc` toolchain.
However, when compiling, icpc insists on using system versions of glibc:
> icpc -cxxlib=/home/user/.linuxbrew/ -std=c++11 hello.cpp -o hello
ld: /home/user/.linuxbrew/Cellar/gcc/5.5.0_4/bin/../lib/gcc/x86_64-unknown-linux-gnu/5.5.0/../../..//libstdc++.so:
undefined reference to `memcpy@GLIBC_2.14'
Instead, I expect it to resolve to glibc 2.23, as installed with homebrew.
`icpc` seems to know about my 5.5 executable:
> icpc -v
icpc version 19.0.0.117 (gcc version 5.5.0 compatibility)
Further, if I explicitly include `~/.linuxbrew/lib` as a linking directory, `ld` succeeds, but the runtime library lookup fails, as it appears that the linker uses system libraries:
> icpc -cxxlib=/home/user/.linuxbrew/ -std=c++11 -L ~/.linuxbrew/lib hello.cpp -o hello
> ldd hello
./hello: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by ./hello)
	linux-vdso.so.1 =>  (0x00007f1781c4c000)
	libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x0000003caee00000)
	libm.so.6 => /lib64/libm.so.6 (0x0000003ca5200000)
	libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x0000003caea00000)
	libc.so.6 => /lib64/libc.so.6 (0x0000003ca4e00000)
	libdl.so.2 => /lib64/libdl.so.2 (0x0000003ca5a00000)
	/lib64/ld-linux-x86-64.so.2 (0x0000003ca4a00000)
I would expect that providing `-cxxlib=<path>` and `-L <inlclude>` should link against libraries in `/home/user/.linuxbrew/lib`.
What am I missing?
Thank you!
Viet_H_Intel
Instead of using -cxxlib=/home/user/.linuxbrew/, can you try -gxx-name=/home/user/.linuxbrew/?
Viet
