Intel® C++ Compiler
intel composer 2013 final problem
serhat_b_
To create your support account, please visit the Subscription Services web site
https://registrationcenter.intel.com/RegCenter/registerexpress.aspx?clientsn=NZC
F-TVT2J9G8
To get started using Intel(R) Composer XE 2013 Update 1 located in
/opt/intel/composer_xe_2013.1.117:
- Set the environment variables for a terminal window using one of the following
  (replace "intel64" with "ia32" if you are using a 32-bit platform).
     For csh/tcsh:
        $ source install-dir/bin/compilervars.csh intel64
     For bash:
        $ source install-dir/bin/compilervars.sh intel64
     To invoke the installed compilers:
        For C++: icpc
        For C: icc
  To get help, append the -help option or precede with the man command.
- To view a table of getting started documents:
  install-dir/Documentation/en_US/get_started_lc.htm
  install-dir/Documentation/ja_JP/get_started_lc.htm
Movies and additional training are available on our website at
www.intel.com/software/products.
q. Quit [default]
Please type a selection or press "Enter" to accept default choice :
bynkln@ubuntu:~$ icc
No command 'icc' found, but there are 25 similar ones
icc: command not found
bynkln@ubuntu:~$ sudo icc
[sudo] password for bynkln:
sudo: icc: command not found
bynkln@ubuntu:~$ source install-dir/bin/compilervars.csh intel64
bash: install-dir/bin/compilervars.csh: No such file or directory
bynkln@ubuntu:~$ ^C
bynkln@ubuntu:~$ q
q: command not found
bynkln@ubuntu:~$ source install-dir/sh/compilervars.bin intel64
bash: install-dir/sh/compilervars.bin: No such file or directory
bynkln@ubuntu:~$ source/opt/intel/bin/compilervars.sh
bash: source/opt/intel/bin/compilervars.sh: No such file or directory
bynkln@ubuntu:~$
can you help very quicly... what should i do to aweake icpc and icc?
Sukruth_H_Intel
Hi, I guess you are not providing the space between "source" and "opt". Usually the default installation directory for "root" installation would be "/opt/intel/ /bin/". So you should check if this is the same directory applicable for you or you have changed the installation dir. SO in order to set the compiler icc or icpc use:- source /opt/intel//bin/compilervars.sh intel64 Please feel free to let me know if you still have any issue with setting the compiler. Regards, Sukruth H V
mecej4
source /opt/intel/bin/compilervars.csh intel64 would work, if the compiler is installed in /opt/intel/. Note the spaces between "source", the path to the shell script, and the "intel64" option.
serhat_b_
thank you very much for quick answer result is: bynkln@ubuntu:~$ source /opt/intel/bin/iccvars.sh intel64 bynkln@ubuntu:~$ source /opt/intel/bin/compilervars.sh intel64 bynkln@ubuntu:~$ icc --version icc (ICC) 13.0.1 20121010 Copyright (C) 1985-2012 Intel Corporation. All rights reserved. bynkln@ubuntu:~$ icpc -version icpc: command line warning #10006: ignoring unknown option '-version' icpc: command line error: no files specified; for help type "icpc -help" bynkln@ubuntu:~$ source /opt/intel/composer_xe_2013.1.117/bin/iccvars.sh intel64 bynkln@ubuntu:~$ source /opt/intel/composer_xe_2013.1.117/bin/compilervars.sh intel64 bynkln@ubuntu:~$ icc --version icc (ICC) 13.0.1 20121010 Copyright (C) 1985-2012 Intel Corporation. All rights reserved. bynkln@ubuntu:~$ icpc --version icpc (ICC) 13.0.1 20121010 Copyright (C) 1985-2012 Intel Corporation. All rights reserved. worked for me!!
