Intel® C++ Compiler
7956 Discussions
intel parallel studio xe 2019 backward compatibility
PDL18
is Intel parallel studio xe 2019 backward compatible with Intel parallel studio xe 2015.
any functionalities  which are depreciated ?
AbhishekD_Intel
Hi Pratik,
Parallel Studio XE has backward compatibility unless the functionality is depreciated or some major change has been made.
As you are comparing with Parallel Studio XE 2015 and 2019 there may be some major deprecation or functionality in the components of PSXE.
So please go through the below link and compare the functionalities depending on your usecase.
https://software.intel.com/content/www/us/en/develop/articles/intel-parallel-studio-xe-release-notes-and-new-features.html
Warm Regards,
Abhishek
PDL18
Viet_H_Intel
Binaries should be compatible. However, some command line options will be deprecated. If you have a PSXE2019 installed, you can run "icc -help deprecated" to see those options listed.
AbhishekD_Intel
Hi Pratik,
Thank you for your confirmation. Intel will no longer monitor this thread. Please post a new thread if you have further issues.
Warm Regards,
Abhishek
