I was able to compile tensorflowv1.12.0 (CPU version) with gcc 4.8.5 (system default) from source, and i am currently having issues while compiling tensorflow with intel. Here are some details wrt. build environment -
- OS Platform and Distribution (e.g., Linux Ubuntu 16.04): CentOS Linux release 7.6.1810 (Core)
- Python version: 3.6.8
- Bazel version : 0.19.1
- GCC/Compiler version : gcc 4.8.5 + intel/19.0.0.117
- CUDA/cuDNN version: NA (CPU Build)
- GPU model and memory: NA (CPU build)
Primary reason for rebuilding with intel/19.0.0.117 is to compare relative performance gain on some sample TF benchmarks.
tensorflow-1.12.0]$ icc --version icc (ICC) 19.0.0.117 20180804 Copyright (C) 1985-2018 Intel Corporation. All rights reserved.
The command used for compilation is as follows -
CC=icc bazel build --config=mkl --define=grpc_no_ares=true --copt=-xHOST //tensorflow/tools/pip_package:build_pip_package
Error messages with aforementioned command line can be found in build_logs.txt & build_logs2.txt
Since bazel seems to be using parallel make (make -j N) type biild, I tried "make"ing tensorflow in "serial mode" as -
CC=icc bazel build -s --config=mkl --jobs=1 --define=grpc_no_ares=true --copt=-xHOST //tensorflow/tools/pip_package:build_pip_package
compilation logs (for --jobs=1) are in file build_logs3_serial1. Please let me know if any further information is required from my end.
I have also posted the issue at tensorflow forum , but as issue is related to intel compilers, i am not expecting much help from tensorflow forum.
Eagerly awaiting your replies.
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
I retried using CC=icpc as -
CC=icpc bazel build -s --config=mkl --jobs=1 --define=grpc_no_ares=true --copt=-xHOST //tensorflow/tools/pip_package:build_pip_package
Breif error message -
/usr/include/string.h(402): error: linkage specification is incompatible with previous "strnlen" (declared at line 160 of "external/nasm/include/compiler.h") extern size_t strnlen (const char *__string, size_t __maxlen) ^
Error log file attached.
I tried manual compilation of a .cc file from bazel cache directory /home/puneet/.cache/bazel/_bazel_puneet/000cc71254e2a8499cd324ebddae445d/execroot/org_tensorflow using the command line which fails during bazel build .
/opt/intel/compilers_and_libraries_2019.0.117/linux/bin/intel64/icpc -U_FORTIFY_SOURCE -fstack-protector -Wall -B/opt/intel/compilers_and_libraries_2019.0.117/linux/bin/intel64 -B/usr/bin -Wunused-but-set-parameter -fno-omit-frame-pointer -g0 -O2 '-D_FORTIFY_SOURCE=1' -DNDEBUG -ffunction-sections -fdata-sections '-std=c++0x' -MD -MF bazel-out/k8-opt/bin/external/boringssl/_objs/ssl/s3_pkt.pic.d '-frandom-seed=bazel-out/k8-opt/bin/external/boringssl/_objs/ssl/s3_pkt.pic.o' -fPIC -iquote external/boringssl -iquote bazel-out/k8-opt/genfiles/external/boringssl -iquote bazel-out/k8-opt/bin/external/boringssl -iquote external/bazel_tools -iquote bazel-out/k8-opt/genfiles/external/bazel_tools -iquote bazel-out/k8-opt/bin/external/bazel_tools -isystem external/boringssl/src/include -isystem bazel-out/k8-opt/genfiles/external/boringssl/src/include -isystem bazel-out/k8-opt/bin/external/boringssl/src/include -xHOST -Wa,--noexecstack '-D_XOPEN_SOURCE=700' -Wall -Werror '-Wformat=2' -Wsign-compare -Wmissing-field-initializers -Wwrite-strings -Wshadow -fno-common '-std=c++11' -Wmissing-declarations -Wno-builtin-macro-redefined '-D__DATE__="redacted"' '-D__TIMESTAMP__="redacted"' '-D__TIME__="redacted"' -c external/boringssl/src/ssl/s3_pkt.cc -o bazel-out/k8-opt/bin/external/boringssl/_objs/ssl/s3_pkt.pic.o
here are the terminal logs -
icpc: command line warning #10006: ignoring unknown option '-frandom-seed=bazel-out/k8-opt/bin/external/boringssl/_objs/ssl/s3_pkt.pic.o' In file included from external/boringssl/src/ssl/s3_pkt.cc(122): external/boringssl/src/ssl/internal.h(191): error #1418: external function definition with no prior declaration T *New(Args &&... args) { ^ In file included from external/boringssl/src/ssl/s3_pkt.cc(122): external/boringssl/src/ssl/internal.h(204): error #1418: external function definition with no prior declaration void Delete(T *t) { ^ In file included from external/boringssl/src/ssl/s3_pkt.cc(122): external/boringssl/src/ssl/internal.h(223): error #1418: external function definition with no prior declaration UniquePtr<T> MakeUnique(Args &&... args) { ^
.c and .h files are attached.
please let me know if any further information is required.
UPDATE: -Werror flag seems to be creating the issue, manual compilation now succeeds. Will try to remove the same from build process config.
-Werror helped and compilation seems to be moving forward. However stuck with another compilation issue.
cd /home/puneet/.cache/bazel/_bazel_puneet/000cc71254e2a8499cd324ebddae445d/execroot/org_tensorflow && \ exec env - \ LD_LIBRARY_PATH=/home/puneet/MySoftwares/COMPILER/JDK/1.8.0.201_precompiled/lib:/home/puneet/MySoftwares/COMPILER/JDK/1.8.0.201_precompiled/lib64:/home/puneet/MySoftwares/UTILS/BAZEL/0.19.1_gcc4.8.5/lib:/home/puneet/MySoftwares/UTILS/BAZEL/0.19.1_gcc4.8.5/lib64:/home/puneet/MySoftwares/COMPILER/PYTHON/3.6.8/lib:/home/puneet/MySoftwares/COMPILER/PYTHON/3.6.8/lib64:/opt/intel/compilers_and_libraries_2019.0.117/linux/compiler/lib/intel64_lin:/opt/intel/compilers_and_libraries_2019.0.117/linux/mpi/intel64/libfabric/lib:/opt/intel/compilers_and_libraries_2019.0.117/linux/mpi/intel64/lib/release:/opt/intel/compilers_and_libraries_2019.0.117/linux/mpi/intel64/lib:/opt/intel/compilers_and_libraries_2019.0.117/linux/ipp/lib/intel64:/opt/intel/compilers_and_libraries_2019.0.117/linux/mkl/lib/intel64_lin:/opt/intel/compilers_and_libraries_2019.0.117/linux/tbb/lib/intel64/gcc4.7:/opt/intel/debugger_2019/libipt/intel64/lib:/opt/intel/compilers_and_libraries_2019.0.117/linux/daal/lib/intel64_lin:/opt/intel/compilers_and_libraries_2019.0.117/linux/daal/../tbb/lib/intel64_lin/gcc4.4 \ PATH=/home/puneet/MySoftwares/COMPILER/JDK/1.8.0.201_precompiled/bin:/home/puneet/MySoftwares/UTILS/BAZEL/0.19.1_gcc4.8.5/bin:/home/puneet/MySoftwares/PYTHONPACKAGES/3.6.8_gnu4.8.5_intel19.0.0.117/PACKAGESUITE/1/bin:/home/puneet/MySoftwares/COMPILER/PYTHON/3.6.8/bin:/opt/intel/compilers_and_libraries_2019.0.117/linux/bin/intel64:/opt/intel/compilers_and_libraries_2019.0.117/linux/mpi/intel64/libfabric/bin:/opt/intel/compilers_and_libraries_2019.0.117/linux/mpi/intel64/bin:/opt/intel/debugger_2019/gdb/intel64/bin:/opt/xcat/bin:/opt/xcat/sbin:/opt/xcat/share/xcat/tools:/usr/lib64/qt-3.3/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/home/puneet/.local/bin:/home/puneet/bin \ PWD=/proc/self/cwd \ /opt/intel/compilers_and_libraries_2019.0.117/linux/bin/intel64/icc -U_FORTIFY_SOURCE -fstack-protector -Wall -B/opt/intel/compilers_and_libraries_2019.0.117/linux/bin/intel64 -B/usr/bin -Wunused-but-set-parameter -fno-omit-frame-pointer -g0 -O2 '-D_FORTIFY_SOURCE=1' -DNDEBUG -ffunction-sections -fdata-sections '-std=c++0x' -MD -MF bazel-out/host/bin/tensorflow/core/kernels/_objs/non_max_suppression_op/non_max_suppression_op.pic.d '-frandom-seed=bazel-out/host/bin/tensorflow/core/kernels/_objs/non_max_suppression_op/non_max_suppression_op.pic.o' -fPIC -DEIGEN_MPL2_ONLY '-DEIGEN_MAX_ALIGN_BYTES=64' -D__CLANG_SUPPORT_DYN_ANNOTATION__ -DTF_USE_SNAPPY -iquote . -iquote bazel-out/host/genfiles -iquote bazel-out/host/bin -iquote external/nsync -iquote bazel-out/host/genfiles/external/nsync -iquote bazel-out/host/bin/external/nsync -iquote external/bazel_tools -iquote bazel-out/host/genfiles/external/bazel_tools -iquote bazel-out/host/bin/external/bazel_tools -iquote external/eigen_archive -iquote bazel-out/host/genfiles/external/eigen_archive -iquote bazel-out/host/bin/external/eigen_archive -iquote external/local_config_sycl -iquote bazel-out/host/genfiles/external/local_config_sycl -iquote bazel-out/host/bin/external/local_config_sycl -iquote external/com_google_absl -iquote bazel-out/host/genfiles/external/com_google_absl -iquote bazel-out/host/bin/external/com_google_absl -iquote external/gif_archive -iquote bazel-out/host/genfiles/external/gif_archive -iquote bazel-out/host/bin/external/gif_archive -iquote external/jpeg -iquote bazel-out/host/genfiles/external/jpeg -iquote bazel-out/host/bin/external/jpeg -iquote external/protobuf_archive -iquote bazel-out/host/genfiles/external/protobuf_archive -iquote bazel-out/host/bin/external/protobuf_archive -iquote external/com_googlesource_code_re2 -iquote bazel-out/host/genfiles/external/com_googlesource_code_re2 -iquote bazel-out/host/bin/external/com_googlesource_code_re2 -iquote external/farmhash_archive -iquote bazel-out/host/genfiles/external/farmhash_archive -iquote bazel-out/host/bin/external/farmhash_archive -iquote external/fft2d -iquote bazel-out/host/genfiles/external/fft2d -iquote bazel-out/host/bin/external/fft2d -iquote external/highwayhash -iquote bazel-out/host/genfiles/external/highwayhash -iquote bazel-out/host/bin/external/highwayhash -iquote external/zlib_archive -iquote bazel-out/host/genfiles/external/zlib_archive -iquote bazel-out/host/bin/external/zlib_archive -iquote external/png_archive -iquote bazel-out/host/genfiles/external/png_archive -iquote bazel-out/host/bin/external/png_archive -isystem external/nsync/public -isystem bazel-out/host/genfiles/external/nsync/public -isystem bazel-out/host/bin/external/nsync/public -isystem third_party/eigen3/mkl_include -isystem bazel-out/host/genfiles/third_party/eigen3/mkl_include -isystem bazel-out/host/bin/third_party/eigen3/mkl_include -isystem external/eigen_archive -isystem bazel-out/host/genfiles/external/eigen_archive -isystem bazel-out/host/bin/external/eigen_archive -isystem external/gif_archive/lib -isystem bazel-out/host/genfiles/external/gif_archive/lib -isystem bazel-out/host/bin/external/gif_archive/lib -isystem external/protobuf_archive/src -isystem bazel-out/host/genfiles/external/protobuf_archive/src -isystem bazel-out/host/bin/external/protobuf_archive/src -isystem external/farmhash_archive/src -isystem bazel-out/host/genfiles/external/farmhash_archive/src -isystem bazel-out/host/bin/external/farmhash_archive/src -isystem external/zlib_archive -isystem bazel-out/host/genfiles/external/zlib_archive -isystem bazel-out/host/bin/external/zlib_archive -isystem external/png_archive -isystem bazel-out/host/genfiles/external/png_archive -isystem bazel-out/host/bin/external/png_archive -g0 -g0 -DEIGEN_AVOID_STL_ARRAY -Iexternal/gemmlowp -Wno-sign-compare -fno-exceptions '-ftemplate-depth=900' '-DINTEL_MKL=1' -DEIGEN_USE_VML -DENABLE_MKL -fopenmp -msse3 -pthread '-DINTEL_MKL=1' -DENABLE_MKL -Wno-builtin-macro-redefined -Wno-error '-D__DATE__="redacted"' '-D__TIMESTAMP__="redacted"' '-D__TIME__="redacted"' -c tensorflow/core/kernels/non_max_suppression_op.cc -o bazel-out/host/bin/tensorflow/core/kernels/_objs/non_max_suppression_op/non_max_suppression_op.pic.o)
compilation error messages -
ERROR: /home/puneet/MySoftwares/INSTALLATION_ROOT/python3/intel/tensorflow-1.12.0/tensorflow/core/kernels/BUILD:2220:1: C++ compilation of rule '//tensorflow/core/kernels:non_max_suppression_op' failed (Exit 2) tensorflow/core/kernels/non_max_suppression_op.cc(120): error: type name is not allowed typename TTypes<float, 2>::ConstTensor overlaps_data = ^ tensorflow/core/kernels/non_max_suppression_op.cc(120): error: expected a ";" typename TTypes<float, 2>::ConstTensor overlaps_data = ^ tensorflow/core/kernels/non_max_suppression_op.cc(122): error: identifier "overlaps_data" is undefined return std::bind(&OverlapsGreaterThanThreshold, overlaps_data, tensorflow/core/kernels/non_max_suppression_op.cc(112): error: expected a ";" typename TTypes<T, 2>::ConstTensor boxes_data = boxes.tensor<T, 2>(); ^ tensorflow/core/kernels/non_max_suppression_op.cc(113): error: identifier "boxes_data" is undefined return std::bind(&IOUGreaterThanThreshold<T>, boxes_data, Target //tensorflow/tools/pip_package:build_pip_package failed to build Use --verbose_failures to see the command lines of failed build steps. INFO: Elapsed time: 135.802s, Critical Path: 119.45s, Remote (0.00% of the time): [queue: 0.00%, setup: 0.00%, process: 0.00%] INFO: 2777 processes: 2777 local. FAILED: Build did NOT complete successfully FAILED: Build did NOT complete successfully
I am attaching files involved in this issue.
Note that the in intel compilation environment, gcc compilers are able to compile the file in question (non_max_suppression_op.cc), but intel compilers are messing up!. Please have a look at - intelv19_issue_non_max_suppression_op.txt .
similar post - https://github.com/tensorflow/tensorflow/issues/25896
please advice.
Can you create a preprocess file (non_max_suppression_op.i) for us?
Seems i am having issues while compiling the file you shared with both gcc & intel,
Could you please help me with correct command line to compile a preprocessed file ?
I tried g++ -stc=c++11 ...... -x cpp-output -c test.cpp -o test.o ?
Terminal log file is attached - for my attempt.
Also, i did not add any additional compilation flag for building tensorflow/non_max_suppression_op.cc. You may use the flags from the log file - shared with my previous comment. bazel is picking up compilation flags from the config files defined deep down the TF source code (seems CROSSTOOL file has setting for same). I need to confirm the config file for compilation flags with tensorflow forum.
test.cpp is your non_max_suppression_op.i after removing all the empty lines.
to get a pre-processed file: replace -c with -E and redirect the output to a file.
after creating a preprocessed file, can you replace non_max_suppression_op.cc with non_max_suppression_op.i and see if it compiles with g++?
I encountered error when compiling your non_max_suppression_op.i with g++. Since you compile the pre-processed file, can you minimize your command lines options and then provide it to us?
Is non_max_suppression_op.i you attached earlier the same with the one you compiled successfully with g++?
