Intel® C++ Compiler
7956 Discussions
internal compiler error (permissions?)
kmhazelw
I installed the Intel C++ compiler as root. When I try to use it to compile anything I get this error:
icc: internal error: error generating temporary file name, check disk space and permissions (shared/driver/hostutil.c, line 901)
The disk is not full, so I assume it is a permissions issue. Where do I need to change permissions?
JenniferJ
do you see the tmp or temp environment variable? if not, it's needed.
Jennifer
kmhazelw
Can you please clarify your response? Are you asking me to SET an environment variable? Doesn't the iccvars script set all of the environment variables it needs?
JenniferJ
the "tmp" or "temp" are set by the OS. In most case they're there. But there're cases they're removed.
it's a guess that maybe the tmp|temp are not defined so the compiler error. if they're defined, it would besomething else.
Jennifer
kmhazelw
If you are asking whether there is a directory called /tmp, then yes it is there and is world writable.
I tried to read between the lines in your previous post and set the environment variables as follows:
export TMP=/tmp
export TEMP=/tmp
export tmp=/tmp
export temp=/tmp
But I still got the same error message. Do you have any concrete suggestions for what else I might try?
kmhazelw
I am sorry. I now see that the /tmp directory was actually not world writeable. Making it world writeable resolved the issue.
JenniferJ
FYI.
we've filed a bug report regarding the "internal error". it should emit an error msg instead.
Jennifer
Milind_Kulkarni__Int
New Contributor II
This issue is fixedand it displaysplain old error message now instead of the compiler failing catastrophically.
