Hi, I was reading two large matrices to multiply them later on.
When compiling with icpc, I got an error message below:
test.cpp(8) (col. 1): internal error: 0_13171
compilation aborted for test.cpp (code 4)
Commenting out any one of the two reading blocks will eliminate the error. What's wrong was going there?
[bash]#include#include #include using namespace std; int main(int argc, char*argv[]) { const int nid(13276); const int len(nid*nid); double gmat[len], ginv[len], prod[len]; int iid, jid, ii; ifstream fge("rst"); fge>>iid; //to discard the first number for(iid=ii=0; iid >gmat[ii++]; for(iid=ii=0; iid >ginv[ii++]; return 0; } [/bash]
which version of the compiler do you use? If I use the latest 12.1 compiler i can not reproduce your error. However, I can reproduce this on older versions of the compiler.
You can download the actual version of the Compiler from the Registration Center.
Alex
It's icpc (ICC) 12.0.5 20110719 on my server
with icpc (ICC) 12.1.0 20110811 on my desktop there is no such error
I will then upgrade it asap.
Many thanks.
Many thanks.
