I have found a bug in compiler when compiling this curiusly-looked sample with /RTCu:
Of course, real code is much complex - it's just a kernel.
Adding "__asm" before the label or putting "goto" instead of "__asm jmp", or removing /RTCu solves the problem.
The version 11.0.066 has no such error.
Nick/
[cpp]int foo(int a) { int s; if(a != 0) { __asm mov s,0 __asm jmp quit } quit: return s; } [/cpp]
Nick/
Quoting - nvruru
Nick/
Nick/
Thanks for reporting this issue. I will report it to engineering team for fix.
-Yang
Topic Options
