Community
cancel
Showing results for
Search instead for
Did you mean:
nvruru
internal error: 0_1752 @ ICL 11.1.051 with /RTCu
I have found a bug in compiler when compiling this curiusly-looked sample with /RTCu:
[cpp]int foo(int a)
  int s;
  if(a != 0)
    __asm mov s,0
    __asm jmp quit
  quit:
  return s;
[/cpp]
Of course, real code is much complex - it's just a kernel.
Adding "__asm" before the label or putting "goto" instead of "__asm jmp", or removing /RTCu solves the problem.
The version 11.0.066 has no such error.
Nick/
Yang_W_Intel
Quoting - nvruru
[cpp]int foo(int a)
  int s;
  if(a != 0)
    __asm mov s,0
    __asm jmp quit
  quit:
  return s;
[/cpp]
Nick/
Thanks for reporting this issue. I will report it to engineering team for fix.
-Yang
