Intel® C++ Compiler
internal error: 010101_14277
Matthias_H_3
Attached is a (preprocessed) source file that triggers the error.
> /opt/intel/compilers_and_libraries/linux/bin/intel64/icpc --version
icpc (ICC) 17.0.2 20170213
Copyright (C) 1985-2017 Intel Corporation.  All rights reserved.
> /opt/intel/compilers_and_libraries/linux/bin/intel64/icpc code.cpp
": internal error: 010101_14277
Matthias
Melanie_B_Intel
This should workaround the bug:
inline SIMD<double> operator+= (SIMD<double> & a, SIMD<double> b) {
  a.Data()+=b.Data();
  return a.Data();
Judith_W_Intel
Thank you for your bug report. I have reduced it to the following and submitted a bug report (DPD200418856) in our bugs database.
extern "C" {
typedef struct __declspec(align(32)) __declspec(intrin_type) __m256d {
    double m256d_f64[4];
} __m256d;
struct SIMD
  __m256d data;
  SIMD();
  SIMD(__m256d);
SIMD operator+= (SIMD a, SIMD b) { return a.data += b.data; }
void foo()
  SIMD s;
  s += s;
Melanie_B_Intel
  a.Data()+=b.Data();
  return a.Data();
Matthias_H_3
Thank you for the workaround.
Matthias
