ldalessa:~/temp$ cat test.cpp #include <atomic> struct Foo { Foo() : foo_() { } std::atomic<int> foo_[2]; }; int main() { } ldalessa:~/temp$ gcc --version gcc (GCC) 4.9.2 Copyright (C) 2014 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. ldalessa:~/temp$ gcc -std=c++11 test.cpp ldalessa:~/temp$ icpc --version icpc (ICC) 15.0.4 20150805 Copyright (C) 1985-2015 Intel Corporation. All rights reserved. ldalessa: ~/temp$ icpc -std=c++11 test.cpp test.cpp(4): internal error: assertion failed at: "shared/cfe/edgcpfe/decl_inits.c", line 6224 Foo() : foo_() { } ^ compilation aborted for test.cpp (code 4)
Current workaround is to skip the initializer for this member variable.
Thanks for your bug report. The problem still exists in our current compiler and I have submitted it as DPD200414465 in our bugs database. The problem can be reproduced in this small test case:
struct atomic
atomic() = default;
struct C {
C() : b() { }
atomic b[2];
I think the constructor initializer (foo_()) in your code is unnecessary for atomics -- the default constructor for each member of the array will automatically be called since each field is default-initialized. So that might be a change (just remove it) that you could use as a workaround.
Judy
Yes, that's the workaround I'm currently using. It's mostly a documentation issue for us at the moment since the resulting code violates our enforced style without an explicit initializer for every field.
I have a simple fix for this which I'm currently testing so it should be fixed in 17.0 update 1.
Good to hear you have an acceptable workaround in the meantime...
