Intel® C++ Compiler
7957 Discussions
internal error: assertion failed at: "shared/cfe/edgcpfe/lower_name.c", line 10541
John_Boltley
I get an internal error when i try to compile http://www.suse.de/~rguenther/tramp3d/tramp3d-v4.cpp.gz with version 13 on Linux. Testcase reduced with C-Reduce:
[cpp]
extern "C" void pthread_key_create ();
class A
public:
    template < typename > struct rebind
        typedef A other;
template < typename _Alloc > struct __alloc_traits
    template < typename _Tp > struct rebind
        typedef typename _Alloc::template rebind < _Tp >::other other;
template < class > struct B;
template < int >class C;
class D
template < int, class > class I:D
template <> class C < 1 >:I < 0, B < C < 0 > > >
template < typename _Tp, typename _Alloc > struct F
    typedef typename __alloc_traits < _Alloc >::template rebind <
    _Tp >::other _Tp_alloc_type;
    struct J:_Tp_alloc_type
        J (_Tp_alloc_type):_Tp_alloc_type ()
    typedef _Alloc allocator_type;
    F (int, const allocator_type & p2):_M_impl (p2)
    } J _M_impl;
template < typename _Tp, typename _Alloc = A > class K:F < _Tp, _Alloc >
    typedef F < _Tp, _Alloc > _Base;
public:
    typedef _Tp value_type;
    K (int, const value_type & = value_type (),
       const allocator_type & p3 = allocator_type ()):_Base (0, p3)
enum CenteringType
{ CellType };
template < int >class H
public:
    H ();
H < 0 > a;
static __typeof pthread_key_create voide
__attribute__ ((__weakref__ ("__pthread_key_create")));
class G
public:
    G (CenteringType = CellType):orientations_m (0), positions_m (0)
    } K < C < 1 > >orientations_m;
    K < int >positions_m;
template < int Dim > H < Dim >::H ()
    new G[0];
[/cpp]
[plain] % icpc test.ii
test.ii(79): internal error: assertion failed at: "shared/cfe/edgcpfe/lower_name.c", line 10541 compilation aborted for test.ii (code 4)
% icpc -v icpc version 13.0.0 (gcc version 4.7.0 compatibility) [/plain]
Alexander_W_Intel
Hi John, Thanks for submitting the issue. I was able to reproduce it. I will take a deeper look into it and reply as soon as I have new information for you. Thanks, Alex
Alexander_W_Intel
Hi John, I forwarded your issue to our development team. The Tracking number is: DPD200236077 Alex
