Hi guys, Getting *multiple* compiler errors with C++17 for ICC 19.0.5. It prevents us from using ICC in the firm forcing to migrate from ICC to clang/gcc. Does 19.0.8 solve the error? Any advice? Sorry, can not figure out the error cause and don't have time to dig in it.
internal error: assertion failed at: "shared/cfe/edgcpfe/lower_init.c", line 11220
Host: Red Hat Enterprise Linux Server release 6.10 (Santiago), GCC 8.3
Same code is compiled fine with ICC 17.0.6 and C++14 mode. Gcc/clang also compile fine.
- Tags:
- CC++
- Development Tools
- General Support
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Could you try with the latest ICC 19.1 and see if it works?
If the latest version also throws error, kindly share the minimal reproducible code sample that is causing the error.
--Rahul
Just quick reminder to provide code sample.
--Rahul
We are closing this thread. Feel free to post a new thread if your issue persists.
