Intel® C++ Compiler
7840 Discussions
internal error: assertion failed at: "shared/cfe/edgcpfe/lower_name.c", line 4241
Matthias_Kretz
I just tested ICC 12.1.3 with Vc and ICC fails compilation on all of my unit tests with the following error:
I would need some help to debug this any further.
Matthias_Kretz
I found a workaround. This may be a hint for the compiler team to debug it.
[cpp]+#ifndef VC_ICC +// ICC ICEs if the following type-traits are in the anonymous namespace namespace { +#endif ... +#ifndef VC_ICC } +#endif[/cpp]
Melanie_B_Intel
Will you please attach a reproducer test case, please include preprocessed source file (-E compiler switch) and compiler invocation.
