../mesh/linunimesh1d.h(42): internal error: assertion failed: copy_template_param_expr: bad expression kind (shared/edgcpfe/il.c, line 12557)
typedef typename True_Element::template Subshape
Relevant definitions:
#define IF_EQUAL(Subshape_Tag, Shape_Tag)
typename bool_<:SHAPE_CLASS>::type
public:
template
template
struct Subshape
typedef Node type;
template
struct Subshape
typedef Edge type;
template
struct Subshape
typedef Face type;
tim18:You haven't given much to go on. Did this fail only as part of a huge source file? If you want this investigated, you should file the problem report on premier.intel.com. Guessing that the compiler may have overflowed some internal table, you might try disabling interprocedural optimization or splitting the source file.
Sorry, I should have filed a better bug report, but I thought the problem was described enough that a test case could be easily generated.
My hunch is that, the error could be due to some hardcoded size limit for template expression string. I attach two files they are equivalent conceptually but one reads more complicated than other. The simple one works ("intel_nobug.cc"), while the complex one fails ("intel_bug.cc")
===intel_nobug.cc===
template
struct is_same
typedef void type;
template
struct is_same
typedef bool type;
struct A
template
template
struct AS
typedef int type;
template
struct AS
typedef double type;
template
struct B
typedef typename A::template AS
main()
B
===intel_bug.cc===
template
struct integral_constant
typedef integral_constant
typedef T value_type;
static const T value = val;
struct true_ : public integral_constant
typedef true_ type;
struct false_ : public integral_constant
typedef false_ type;
template
template<> struct bool_
enum shape_class_t {ST_NONE, NODE, EDGE, FACE, FOLD};
struct Node_Tag
typedef Node_Tag Shape_Tag;
static const shape_class_t shape_class = NODE;
static const shape_class_t previous_class = ST_NONE;
static const shape_class_t next_class = EDGE;
struct Edge_Tag
typedef Edge_Tag Shape_Tag;
static const shape_class_t shape_class = EDGE;
static const shape_class_t previous_class = NODE;
static const shape_class_t next_class = FACE;
struct Node {};
struct Edge {};
struct Element
template
template
struct Subshape
typedef Node type;
template
struct Subshape
typedef Edge type;
template
struct Some
typedef typename Element::template Subshape
main()
Some
===intel_bug.cc===
Dale
Thank you for reporting this bug. I have entered it into our internal bug
database (tracker number #82149). The problem seems to occur when
trying to copy the static data member part of the template expression inside
the IF_EQUAL macro. To workaround it, you might try changing your code
as shown in this diff:
Change the code as shown below (this removes the
use of the static data members in the template argument
expression):
sptxl2-424> diff -c intel_bug.cc fixed.cc
*** intel_bug.cc2007-12-27 21:59:28.000000000 -0500
--- fixed.cc2007-12-27 22:16:19.000000000 -0500
*** 34,54 ****
!typename bool_<:SHAPE_CLASS>::type
struct Node {};
struct Edge {};
struct Element
!template
template
!struct Subshape
typedef Node type;
template
!struct Subshape
typedef Edge type;
--- 34,54 ----
!bool_<:SHAPE_CLASS>
struct Node {};
struct Edge {};
struct Element
!template
template
!struct Subshape
typedef Node type;
template
!struct Subshape
typedef Edge type;
thanks again for reporting this to us.
Judy
