Intel® C++ Compiler
7781 Discussions
internal error: assertion failed: macro_invocation: unknown special predefined macro
haiming__yin
I encounter a failure at Version 17.0.4.210 Build 20170411​
it can be reproduced with these codes( test.c):
int main(int argc,char** argv)
#ifdef __DEC32_MAX__
    float i2 = __DEC32_MAX__;
#endif
    return 0;
compile the souce with: "icl test.c " or "icl /E test.c", get the error message:
test.c(4): internal error: assertion failed: macro_invocation: unknown special predefined macro (shared/cfe/edgcpfe/macro.c, line 5750)
can some one help with this issue? is this a bug of the compiler?
Melanie_B_Intel
Yes, this is a compiler bug. I opened CMPLRS-47067​ in our internal database. Thank you for reporting it.
haiming__yin
thank you for the confirmation. In addition, some other macros come up with the same failure. list them bellow:
__DEC128_EPSILON__
__DEC128_MAX__
__DEC128_MIN__
__DEC128_SUBNORMAL_MIN__
__DEC32_EPSILON__
__DEC32_MIN__
__DEC32_SUBNORMAL_MIN__
__DEC64_EPSILON__
__DEC64_MAX__
__DEC64_MIN__
__DEC64_SUBNORMAL_MIN__
