Intel® C++ Compiler
7875 Discussions
internal error: assertion failed: remove_from_routines_list: routine not found on list (shared/cfe/edgcpfe/il.c, line 16415)
sav
Hello, everyone,
For Boost.Python builds using ICC on Windows got error:
libs\python\src\object\enum.cpp(47): internal error: assertion failed: remove_from_routines_list: routine not found on list (shared/cfe/edgcpfe/il.c, line 16415)
          object auto_free(handle<>(mod));
compilation aborted for libs\python\src\object\enum.cpp (code 4)
(original 'enum.cpp' and its ICC-preprocessed version added in attachment).
Reproduced for:
  - Boost 1.66.0.b1.rc2 builds using ICC,
not reproduced for:
  - Boost 1.65.1 builds using ICC,
  - Boost 1.66.0.b1.rc2 builds using mingw-w64 and MSVC.
Environment:
  • Windows 10 x64,
  • ICC 2018 Update 1,
  • MSVC 2017 15.4.1,
  • Windows SDK 10.0.16299.15,
  • mingw-w64 x86_64 7.2.0,
  • Boost 1.66.0.b1.rc2.
Best,
Alexander
Judith_W_Intel
Thank you for reporting this. I have reduced it to the following code (which only fails on Windows):
namespace boost {
extern "C"
void foo()
   void auto_free(int);
It seems to be a problem with a block scope declaration inside an extern "C" routine which is inside a namespace.
I have submitted this in our internal compilers database as cmplrs-47253.
Judith_W_Intel
namespace boost {
extern "C"
void foo()
sav
After moving to IPSXE 2018 Update 2 error not reproduced. Thank you for fix!
Best,
Alexander
