Steps to reproduce:
$ wget https://www.python.org/ftp/python/3.6.4/Python-3.6.4.tar.xz $ tar -xaf Python-3.6.4.tar.xz $ cd Python-3.6.4/ $ ./configure --with-icc $ icc -I Include -I. -c Modules/_sha3/sha3module.c -o tmp.o ": internal error: ** The compiler has encountered an unexpected problem. ** Segmentation violation signal raised. ** Access violation or stack overflow. Please contact Intel Support for assistance. compilation aborted for Modules/_sha3/sha3module.c (code 4)
- Tags:
- CC++
- Development Tools
- Intel® C++ Compiler
- Intel® Parallel Studio XE
- Intel® System Studio
- Optimization
- Parallel Computing
- Vectorization
Hi Mike,
Can you please create a preprocess (sha3module.i), by replace -c with -E, and attach it to us to investigate?
Viet
Thanks, I've reproduced the problem and will submit this bug to our developer for a fix.
Viet
Hello Viet,
did this fix make it into 2018.2?
Cheers, Peter
I was also seeing this problem with Intel compilers 2018 update 1, when building Python 3.6.4.
It turns out that there's a workaround for this: the underlying cause for the segmentation fault seems to be that there's a stack limit in place (see output of "ulimit -s"). You may be able to dance around the issue by setting the stack limit to unlimited using "ulimit -s unlimited" (whether that'll work depends on the hard limit, see "ulimit -s -H").
I'm not seeing this problem anymore when building Python 3.6.4 with Intel compilers 2018 update 3 with a stack limit in place, so it seems like the bug has been fixed in either 2018 update 2 or 3.
