I reproducibly get an
internal error: assertion failed at: "shared/cfe/edgcpfe/checkdir.c", line 5595
when compiling https://github.com/wwu-numerik/DUNE-Multiscale/blob/threaded_msfem/dune/multiscale/common/righthands... with icpc 14.0.1 20131008 on ubuntu 13.10 with gcc 4.7.3 and -fopenmp and -std=c++11. The assertion does not trigger if I disable the parallel section by commenting line 155. I have a couple more, similar regions in other compile units that never trigger the assertion.
Any advice?
Thank you, I received your test case and confirm it's DPD200248106 which should be fixed in the next update.
This looks like it may be the same issue as DPD200248106 in our internal bugs database. Would you be able to supply preprocessed test case? (compile with -E switch and save the output)
I've uploaded a txt containing the output twice via the below form, but it doesn't show anywhere before submitting...
So maybe I can :)
