Hi, getting the follownig error compiling some c++ codes using the icpc version 11.1.46.
These same codes have compiled without incident using previous versions of the intel compilers.
(0): internal error: 0_0
It would be nice if you can provide the testcase and compilation command to narrowdown the issue. You may submit preprocessed file as a test case. You can generate the pressed file using -P compiler option and can attach to this forum post.
Does it compile with -O0?
Topic Options
