Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
internal error intel compiler 11.1 on mac
Hi, getting the follownig error compiling some c++ codes using the icpc version 11.1.46.
(0): internal error: 0_0
These same codes have compiled without incident using previous versions of the intel compilers.
Highlighted
It would be nice if you can provide the testcase and compilation command to narrowdown the issue. You may submit preprocessed file as a test case. You can generate the pressed file using -P compiler option and can attach to this forum post.
Highlighted
Does it compile with -O0?
