Is it OK that the code compiled with -ip option is incompatible with the code compiled without -ip?
- « Previous
- 1
- 2
- Next »
Max, I just tried with our latest 15.0 beta version of our compiler and it passes successfully. I'll keep you updated as soon as the 15.0 version is released. In the meantime, let me know if you want me to add your name to the beta invite list for 15.0?
_Regards, Kittur
Kittur, why not? It's better to find problems before release ) So feel free to add me to the beta invite list.
Also, it would be good to know if I've chosen the right workaround of this problem with current compiler version. I mean compiling my code with -ip switch. Theoretically it could be so, that it just hides the problem and crashes can happen in other places or in other conditions.
Max, I agree and I've passed on your name to the beta coordinator for adding to the beta invite list. With regard to whether using -ip as a workaround I am awaiting a response from our dev team and will update you as soon as I get a confirmation. Again, appreciate your patience :-)
_Kittur
Max, this issue is still being investigated by our dev team and will keep you updated as soon as I've some response on their investigation, fyi.
_kittur
Hi Max,
Thanks for your patience, the latest 15.0 Update 1 release contains the fix for this issue which you can download from the Intel Registration Center, appreciate much.
_Kittur
- « Previous
- 1
- 2
- Next »
