Intel® C++ Compiler
ipo warning #11024
_____1
Hello.
This is my ploblem.
I installed Intel C++ Composer XE 2011 update 3 for correspoing to VS2010.
I builded on release mode, I get following warning.
ipo : warning #11024: main entry point is not found.
ipo-1 : warning #11024: main entry point is not found.
ipo-2 : warning#11024: main entry point is not found.
ipo-3 : warning #11024: main entry point is not found.
ipo-4 : warning #11024: main entry point is not found.
Build component is dll, and there is DLLMain() API.
So I can notresolve this warning.
Please help me.
Feilong_H_Intel
Hi there,
I created a simple DLL project with VS wizard. Then converted to Intel C++ project and enabled IPO. Unfortunately I didn't see the ipo warning you mentioned. Is it possible for you to upload a small project that demostrates the problem?
Thank you.
Feilong H.
Intel Developer Support
Tools Knowledge Base: http://software.intel.com/en-us/articles/tools
