Compiler XE 14 and boost 1.54
errors:
error #373: "boost::asio::detail::noncopyable::noncopyable(const boost::asio::detail::noncopyable &)" (declared at line 32 of "path removed\boost/asio/detail/noncopyable.hpp") is inaccessible path removed\boost\asio\basic_streambuf.hpp
error : class "boost::asio::basic_socket_iostream<boost::asio::ip::tcp, boost::asio::stream_socket_service<boost::asio::ip::tcp>, boost::posix_time::ptime, boost::asio::time_traits<boost::posix_time::ptime>, boost::asio::deadline_timer_service<boost::posix_time::ptime, boost::asio::time_traits<boost::posix_time::ptime>>>" has no member "read_some" path removed\boost\asio\impl\read.hpp
Please explain.
This issue is new. Could you please attach the .i file and command line?
Jennifer
I dont have an .i file anywhere, I'm using visual studio 2010 if that makes a difference.
I fixed the second error but still having trouble with the first:
"boost::asio::detail::noncopyable::noncopyable(const boost::asio::detail::noncopyable &)" (declared at line 31 of "path removed\boost/asio/detail/noncopyable.hpp") is inaccessible
1> private noncopyable
1> ^
if I comment private in the noncopyable class:
class noncopyable{ protected: noncopyable() {} ~noncopyable() {} private: noncopyable(const noncopyable&); const noncopyable& operator=(const noncopyable&); };
I get an LNK2019 instead
You would make the pre-processed file by a command line such as
icl -E -I..... *.cpp > your.i
This would show how the includes were resolved.
A mixture of forward and back slashes in paths doesn't look right.
commanderlake wrote:
Got the .i files but they are huge!
It is normal for preprocessed files to have size of several hundreds megabytes, if not gigabytes. You can always zip them and upload an archive.
I meant big for files containing text, they are a perfectly manageable size, the most significant one I uploaded with my last post.
[....] I uploaded with my last post.
oops, I must have been overworked, I have not noticed that fact, sorry for the noise :-)
My project is on hold till I solve this.
I got other different errors with the .i file. which VC are you using? are you building for x64 or win32?
Jennifer
I am working on a similar problem. I can reproduce the error with your test case and icl 14.0:
C:\Users\Administrator\Documents\Visual Studio 2010\boost154\boost/asio/basic_streambuf.hpp(113): error #373: "boost::asio::detail::noncopyable::noncopyable(const boost::asio::detail::noncopyable &)" (declared at line 31 of "C:\Users\Administrator\Documents\Visual Studio 2010\boost154\boost/asio/detail/noncopyable.hpp") is inaccessible
private noncopyable
detected during:
implicit generation of "boost::asio::basic_streambuf<Allocator>::basic_streambuf(const boost::asio::basic_streambuf<std::allocator<char>> &) [with Allocator=std::allocator<char>]" at line 161 of "RCClientPPDlg.cpp"
instantiation of class "boost::asio::basic_streambuf<Allocator> [with Allocator=std::allocator<char>]" at line 161 of "RCClientPPDlg.cpp"
Does the code compile with the Microsoft compiler (unless of course you are using Intel-specfic syntax)?
I worked around the issue by simply removing the noncopyable attribute (or whatever its called).
