I'm looking for the equivalent of -w or -diag-disable for icpc but which would work with xiar. I've found no switch to tell it to be quiet and setting -diag-disable in icc.cfg and icpc.cfg does not influence it either. The messages I'm talking about look like:
ipo: remark #11001: performing single-file optimizations
ipo: remark #11005: generating object file /tmp/xiarM4ZcQr_ipo/myfile.o
which, for normal use, are utterly pointless.
Quoting - Olivier
Probably flag existing ?? I don't know
Supposing problem that you want show clear event errors
use make 2>&1 | tee info.txt
You having all informations storage to file info.txt
You can also increasing terminal the number lines memory from back scroll.
If you using parallel make --jobs=8, I don't know what result can be contain
file ??
Best regards
Quoting - bustaf
Hi
file ??
Best regards
file ??
Best regards
I could always wrap xiar in a script and pipe its output through grep... but I can't believe I'm the only one to have no use for these messages.
