Intel® C++ Compiler
7956 Discussions
ivdep-parallel and help-pragma not working on ICC v11.1
inthecrossfire
As far as I can tell, ICC v11.1 should support the parameter -ivdep-parallel to ignore loop dependencies for vectorisation. When I try and compile code using it I get:
$ icc -ivdep-parallel -o test test.c
icc: command line warning #10156: ignoring option '-i'; no argument required
Also, I tried to get a list of pragmas that the documentation suggests is available through help-pragma. With this I get:
$ icc -help-pragma
icc: command line error: no files specified; for help type "icc -help"
I'm building on CentOS 5 on a 64-bit machine. Have I just been reading the wrong documentation or am I missing something very obvious? Thanks.
Alexander_W_Intel
you can always use the "pragma ivdep" to mark loop as independend.
The error with -help-pragma is a know issue. The workaround is to also specify a source file.
# icc -help-pragma test.c
Alex
inthecrossfire
From the ICC man page, it sounds like you need to use -ivdep-parallel in conjunction with #pragma ivdep to get loop dependencies to be ignored. Here's a simple example that should be able vectorise.
[cpp]void addFour(int *array, int nx, int ny)
	int x,y,z;
#pragma ivdep
	for (z=0;z
And it gives the following vec-report. Should the #pragma work in this case?
[bash]icc -O3 -vec-report3 -c -o ivdep.o ivdep.c
ivdep.c(7): (col. 2) remark: loop was not vectorized: not inner loop.
ivdep.c(9): (col. 3) remark: loop was not vectorized: not inner loop.
ivdep.c(11): (col. 4) remark: loop was not vectorized: existence of vector dependence.
ivdep.c(13): (col. 5) remark: vector dependence: assumed FLOW dependence between array line 13 and array line 13.
ivdep.c(13): (col. 5) remark: vector dependence: assumed ANTI dependence between array line 13 and array line 13.
ivdep.c(13): (col. 5) remark: vector dependence: assumed ANTI dependence between array line 13 and array line 13.[/bash]
example-ivdep.zip
Milind_Kulkarni__Int
New Contributor II
As for the ivdep-parallel option, its an i64 only..
Applications for the IA-64 architecture
The -ivdep-parallel (Linux) or /Qivdep-parallel (Windows) option implies there is no loop-carried dependency in the loop where an ivdep pragma is specified. (This strategy is useful for sparse matrix applications.)
Are you using IA64 system..
Also, when I use the later compilers like 12.0/12.1, I get the inner loop as vectorized..
mkulka3@dpd20:~> icc -V
Intel C Intel 64 Compiler XE for applications running on Intel 64, Version 12.1.0.233 Build 20110811
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
mkulka3@dpd20:~> icc -O3 -vec-report3 -c ivdep.c
ivdep.c(11): (col. 4) remark: LOOP WAS VECTORIZED.
Perhaps, you could use compilers that are currently supported..
levicki
Valued Contributor I
help-pragma option still doesn't work in 2011 SP1 (Update 6), will this issue ever be fixed or will it stay forever as a "known issue"?
Alexander_W_Intel
I asked back on engineering. I will give you an update as soon as I get an answer.
Alex
Alexander_W_Intel
This issue is fixed in the latest Studio XE 2016 Composer Edition product.  Please refer to this article for new product names.
Alex
