$ icc -ivdep-parallel -o test test.c
icc: command line warning #10156: ignoring option '-i'; no argument required
Also, I tried to get a list of pragmas that the documentation suggests is available through help-pragma. With this I get:
$ icc -help-pragma
icc: command line error: no files specified; for help type "icc -help"
I'm building on CentOS 5 on a 64-bit machine. Have I just been reading the wrong documentation or am I missing something very obvious? Thanks.
[cpp]void addFour(int *array, int nx, int ny) { int x,y,z; #pragma ivdep for (z=0;z
[bash]icc -O3 -vec-report3 -c -o ivdep.o ivdep.c ivdep.c(7): (col. 2) remark: loop was not vectorized: not inner loop. ivdep.c(9): (col. 3) remark: loop was not vectorized: not inner loop. ivdep.c(11): (col. 4) remark: loop was not vectorized: existence of vector dependence. ivdep.c(13): (col. 5) remark: vector dependence: assumed FLOW dependence between array line 13 and array line 13. ivdep.c(13): (col. 5) remark: vector dependence: assumed ANTI dependence between array line 13 and array line 13. ivdep.c(13): (col. 5) remark: vector dependence: assumed ANTI dependence between array line 13 and array line 13. ivdep.c(13): (col. 5) remark: vector dependence: assumed FLOW dependence between array line 13 and array line 13. ivdep.c(13): (col. 5) remark: vector dependence: assumed FLOW dependence between array line 13 and array line 13. ivdep.c(13): (col. 5) remark: vector dependence: assumed ANTI dependence between array line 13 and array line 13. ivdep.c(13): (col. 5) remark: vector dependence: assumed ANTI dependence between array line 13 and array line 13. ivdep.c(13): (col. 5) remark: vector dependence: assumed FLOW dependence between array line 13 and array line 13. ivdep.c(13): (col. 5) remark: vector dependence: assumed FLOW dependence between array line 13 and array line 13. ivdep.c(13): (col. 5) remark: vector dependence: assumed ANTI dependence between array line 13 and array line 13. ivdep.c(13): (col. 5) remark: vector dependence: assumed ANTI dependence between array line 13 and array line 13. ivdep.c(13): (col. 5) remark: vector dependence: assumed FLOW dependence between array line 13 and array line 13. ivdep.c(13): (col. 5) remark: vector dependence: assumed ANTI dependence between array line 13 and array line 13. ivdep.c(13): (col. 5) remark: vector dependence: assumed FLOW dependence between array line 13 and array line 13. ivdep.c(13): (col. 5) remark: vector dependence: assumed FLOW dependence between array line 13 and array line 13. ivdep.c(13): (col. 5) remark: vector dependence: assumed ANTI dependence between array line 13 and array line 13. ivdep.c(13): (col. 5) remark: vector dependence: assumed ANTI dependence between array line 13 and array line 13. ivdep.c(13): (col. 5) remark: vector dependence: assumed FLOW dependence between array line 13 and array line 13. ivdep.c(13): (col. 5) remark: vector dependence: assumed FLOW dependence between array line 13 and array line 13. ivdep.c(13): (col. 5) remark: vector dependence: assumed ANTI dependence between array line 13 and array line 13. ivdep.c(13): (col. 5) remark: vector dependence: assumed ANTI dependence between array line 13 and array line 13. ivdep.c(13): (col. 5) remark: vector dependence: assumed FLOW dependence between array line 13 and array line 13. ivdep.c(13): (col. 5) remark: vector dependence: assumed FLOW dependence between array line 13 and array line 13. ivdep.c(13): (col. 5) remark: vector dependence: assumed ANTI dependence between array line 13 and array line 13.[/bash]example-ivdep.zip
Applications for the IA-64 architecture
The -ivdep-parallel (Linux) or /Qivdep-parallel (Windows) option implies there is no loop-carried dependency in the loop where an ivdep pragma is specified. (This strategy is useful for sparse matrix applications.)
Are you using IA64 system..
Also, when I use the later compilers like 12.0/12.1, I get the inner loop as vectorized..
mkulka3@dpd20:~> icc -V
Intel C Intel 64 Compiler XE for applications running on Intel 64, Version 12.1.0.233 Build 20110811
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
mkulka3@dpd20:~> icc -O3 -vec-report3 -c ivdep.c
ivdep.c(11): (col. 4) remark: LOOP WAS VECTORIZED.
Perhaps, you could use compilers that are currently supported..
This issue is fixed in the latest Studio XE 2016 Composer Edition product. Please refer to this article for new product names.
Alex
