Hello.
I was wondering if the following is a known issue and/or has a workaround. This code fails to compile when any of the problematic lines is uncommented (error messages are provided in comments):
#includetemplate< typename some_type > class some_class { public: void fn1() { auto qwe = [](){}; auto asd = ( std::function< void() > )qwe; } static void fn2() { auto qwe = [](){}; auto asd = ( std::function< void() > )qwe; } void fn3( std::function< void() > f ) { std::function< void() > _f = (){f();}; } void fn4( const std::function< void() > &f ) { std::function< void() > _f = (){f();}; } }; int main() { some_class x; // uncomment any of the followings 4 lines: x.fn1(); // internal error: backend signals //some_class ::fn2(); // internal error: backend signals //x.fn3( [](){} ); // internal error: type_pointed_to: not a pointer type //x.fn4( [](){} ); // internal error: backend signals return 0; }
This also fails:
class some_non_template_class { public: void fn3( std::function< void() > f ) { std::function< void() > _f =(){f();}; // internal error: type_pointed_to: not a pointer type } };
Versions:
Intel C++ Compiler XE for applications running on IA-32, Version 12.1.2.278 Build 20111128;
MSVS 2010 SP1 (MSVC compiles this just fine).
Have tried compiling from IDE, and also with just "icl main.cpp"
Vladimir
Hello Vladimir,
all the errors you see (named internal error) are compiler defects. I've submitted a defect (edit: DPD200177954) to our engineers to fix this. I'm also asking them for workarounds and come back to you as soon as I have more information.
Sorry for the inconvenience & best regards,
Georg Zitzlsberger
Georg Zitzlsberger
Thanks a lot, had a similar problem myself was wondering what was going on.
Thank you, Georg.
those internal compiler errors just got fixed and will be available with Intel Composer XE 2011 Update 10.
Georg Zitzlsberger
Georg Zitzlsberger
Topic Options
