Intel® C++ Compiler
7876 Discussions
libifcore missing in the newest version of C++ compiler (2017.2.044)
Laura_S_1
I am trying to compile a C++ code and need to use the libifcore library. However, it is not contained in my version (2017.2.044) of the Intel System Studio. I discovered, that in slightly less recent versions (e.g. 2017.1.132) that library was still contained.
Has it just been renamed now? If yes, what is it called now? If not - since I do need that library file, where can I get it?
Hopefully you can help me with this!
Thank you,
Laura
TimP
Black Belt
In my recent installations, it looks like ifcore is supported only as a Fortran source and .mod file.  Presumably, the library is installed when you install ifort.  The slightly older version would likely work.
SergeyKostrov
Valued Contributor II
Here is a screenshot after I searched the libifcore on Linux Ubuntu 16.04 LTS with Intel PS XE 2017 Cluster Edition Update 2 installed.
SergeyKostrov
As you can see 32-bit and 64-bit libraries are installed on Linux. Note: I have Full installation of Intel C++ compiler. >>...2017.2.044... Is that for Windows?
