Hi
When building an application on 32bit Linux I get the linker problem
/compiler -liomp5 -lpthread -lc -ldl
/remote/public/linux/opt/intel/composerxe-2011.2.137/compiler/lib/ia32/libiomp5.so: undefined reference to `__umoddi3'
/remote/public/linux/opt/intel/composerxe-2011.2.137/compiler/lib/ia32/libiomp5.so: undefined reference to `__moddi3'
scons: *** [bld/skive32/devel/default/intelc-12.0.2/bin/moseksi] Error 1
scons: building terminated because of errors.
I use version 12.0.2. Any suggestions for a fix?
Let also say the application build without problems using Intel C 11.1.
It seems that you don't have the 32-bit g++ development system installed where you are executing.
Ok. But my application is a pure C application. So I still need g++?
Intel compilers invoke g++ to find the paths and libraries, even when not compiling C++. The g++ and other gcc components must be from the identical release (g++ -version, gcc -version, ....). I agree, in this case, the library which it seems was missing from the link belongs to gcc, but it does look like icc didn't find it. Adding -# to your icc options (verbose) may verify this.
