Intel® C++ Compiler
Support and discussions for creating C++ code that runs on platforms based on Intel® processors.
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
For the latest information on Intel’s response to the Log4j/Log4Shell vulnerability, please see Intel-SA-00646
7594 Discussions
libucrt.lib(nan.obj) : error LNK2005: nan already defined in libmmt.lib(nan.obj)
mikeitexpert
New Contributor II
Dear Experts,
I am experience a link error :
OS: Windows 10
MSVC : 2019
ICC : Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.2.254 Build 20200623
xilink /nodefaultlib:vcomp /nodefaultlib:crt libiomp5md.lib -LIBPATH:Debug\lib -out:Debug/target.exe DEBUG/obj/target_object.obj lib_some_internal_lib.lib
xilink: executing 'link'
Microsoft (R) Incremental Linker Version 14.26.28806.0
Copyright (C) Microsoft Corporation. All rights reserved.
/nodefaultlib:vcomp
/nodefaultlib:crt libucrt
libiomp5md.lib
-LIBPATH:Debug\lib
-out:Debug/ark_cpplab.exe
libucrt.lib(nanf.obj) : error LNK2005: nanf already defined in libmmt.lib(nan.obj)
Debug\target.exe : fatal error LNK1169: one or more multiply defined symbols found
Any comment is much appreciate it.
mikeitexpert
New Contributor II
Please let me know if there is any update on this. I googled pretty much everywhere and couldn't find a solution yet.
mikeitexpert
New Contributor II
SUCCESS ... I don't know how and why it solved the problem but I just added /MD to compile flags and the issue sorted out. If I check Reference and Guide it says "Tells the linker to search for unresolved references in a multi-threaded, dynamic-link run-time library!"
RahulV_intel
Since you have figured out the issue, I will go ahead and close this thread. Intel will no longer monitor this thread. However, it will remain open for community discussion.
--Rahul
