Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
macOS compilervars, how to use with zsh
known issue:
macOS zsh how to use compilervars.sh
PSXE 2020 for macOS*:  compilervars.sh currently does not support zsh.  We're making the 'vars' scripts to be POSIX compliant in the future which will address this issue.
Simplest workaround is:
% bash -c 'source /opt/intel/bin/compilervars.sh intel64 ; exec zsh'
Which will end up with a new zsh instance, so if you exit from the new instance you will lose the env vars.
