How do I match the asm code listing with the souce code of the inline function? I can get the asm/source code listing for the normal functionby using the compiler switch but not the inline function.
Unfortunately I don't think there's a good way to do that currently. I believe we may have better facilities for this in future versions, but for now it will take some detective work. You might compare against a version with inlining disabled (-Ob0 on Linux) and see if you kind find the info you're looking for. It kinda depends on exactly what you're trying to accomplish.
Hope that helps. If you can give me more details we can brainstorm a bit.
Dale
Topic Options
