I have a couple of questions on the usage of the math library in windows (64bit, vs2010).
In the documentation of the intel c++ compiler (12.1), in the article "Using Intel Math Library" a simple program appropriate for windows is presented and then the user is instructed to add the compilation flags /Qlong-double /Qpc80 . After adding them in the Additional Compile Options of project properties (there is no visual entry for this), I got a warning that the options are not recognized and therefore ignored . What am I doing wrong ?
Also, tried to go through the mathimf.h file and so some ppc macro __INTEL_COMPILER (or something very similar). Where is this defined ? Should I define it ? Also there seems to be __ICL etc. where can one obtain a list of the meaning of these macros ? Unfortunately the documentation shipped with the product (Parallel Studio 2011) leaves some to be desired..
Thank you in advance for your help,
Petros
- « Previous
- Next »
Sergey Kostrov wrote:
>>>>...In particular I don't know what RTuint, RTint, _RTFPU_PC_64 and _RTFPU_MCW_PC are...
>>...do these typedefs belong to your Real time library?Yes and I provided a short instruction on required changes a couple of posts before this one. RT stands for Run-Time.
I confused it with Real-Time library.IIRC few months ago you talked about the such a library.
Sergey,
I have never used ieee.c. Simply including the float.h and the mathimf.h.
I think it is better to wait for your test project (it is already Thursday, even beginning/middle of next week would be very OK )
.Thank you very much for all your help !
P-
and it comes from msvcr80d.dll. In Debug configuration expression ( mask &~ ( _MCW_DN | _MCW_EM | _MCW_RC ) ) == 0 checks that _MCW_PC bits are not set ( you need to press Ignore button because the message is actually a warning ).
Sergey,
These are very comprehensive tests and thank you very much for this.
I unzipped the files and openned the solution fputest.vs05 win vs2010 which transormed it into a 2010 solution - should presumably be innocuous.
On Building I got :
1>------ Rebuild All started: Project: FpuTestApp, Configuration: Debug Win32 ------
1>Build started 1/27/2013 8:15:26 PM.
1>_PrepareForClean:
1> Deleting file "Debug\FpuTestApp.lastbuildstate".
1>InitializeBuildStatus:
1> Creating "Debug\FpuTestApp.unsuccessfulbuild" because "AlwaysCreate" was specified.
1>MessageBuildingWithCompiler:
1> Building with Intel(R) C++ Compiler 12.1
1>ClCompile:
1> ***** ClCompile (Win32 - Intel C++)
1>icl : warning #10148: option '/Qlong-double' not supported
1>icl : warning #10148: option '/Qpc80' not supported
1> Stdafx.cpp
1> FpuTestApp.cpp
1>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\Microsoft.CppBuild.targets(990,5): warning MSB8012: TargetPath(C:\_petros\_otc\tests\FpuTestApp.Icc\Debug\FpuTestApp.exe) does not match the Linker's OutputFile property value (C:\_petros\_otc\tests\FpuTestApp.Icc\Debug\FpuTestApp32D.exe). This may cause your project to build incorrectly. To correct this, please make sure that $(OutDir), $(TargetName) and $(TargetExt) property values match the value specified in %(Link.OutputFile).
1>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\Microsoft.CppBuild.targets(992,5): warning MSB8012: TargetName(FpuTestApp) does not match the Linker's OutputFile property value (FpuTestApp32D). This may cause your project to build incorrectly. To correct this, please make sure that $(OutDir), $(TargetName) and $(TargetExt) property values match the value specified in %(Link.OutputFile).
1>Link:
1> xilink: executing 'link'
1>Manifest:
1> Deleting file "Debug\FpuTestApp.exe.embed.manifest".
1>LinkEmbedManifest:
1> FpuTestApp.VS05.vcxproj -> C:\_petros\_otc\tests\FpuTestApp.Icc\Debug\FpuTestApp.exe
1>FinalizeBuildStatus:
1> Deleting file "Debug\FpuTestApp.unsuccessfulbuild".
1> Touching "Debug\FpuTestApp.lastbuildstate".
1>
1>Build succeeded.
1>
1>Time Elapsed 00:00:02.51
which is due to the naming of the file (in the debug version in vs2010 the output goes to different directories so there is no collision issue).
1>Build started 1/27/2013 8:19:49 PM.
1>_PrepareForClean:
1>ClCompile:
1> Stdafx.cpp
1> FpuTestApp.cpp
1>Link:
1>Manifest:
1>
1>Build succeeded.
1>
1>Time Elapsed 00:00:02.45
========== Rebuild All: 1 succeeded, 0 failed, 0 skipped ==========
For x64 configuration though the result was :
64-bit Windows platform - Configuration: DEBUG
Test-Case 1
Size of [ long double ] is: 8
Test-Case 2
Not executed on a 64-bit Windows platform
Test-Case 3.1
Press any key to continue . . .
After I changed this I got ( 32bit configuration on 64bit windows):
32-bit Windows platform - Configuration: RELEASE
Test-Case 1
Test-Case 2
_CW_DEFAULT & ALLBITSON: 0x9001F
_PC_24 & _MCW_PC : 0xA001F
_PC_53 & _MCW_PC : 0x9001F
_PC_64 & _MCW_PC : 0x8001F
Test-Case 3.1
Accuracy _CW_DEFAULT - long double - Result: 1.0000000000079181
Sub-Test 3.2
Accuracy _PC_24 - long double - Result: 1.0000000000079181
Test-Case 3.3
Accuracy _PC_53 - long double - Result: 1.0000000000079181
Test-Case 3.4
Accuracy _PC_64 - long double - Result: 1.0000000000079181
Test-Case 4
Matrix A
101.0 201.0 301.0 401.0 501.0 601.0 701.0 801.0
901.0 1001.0 1101.0 1201.0 1301.0 1401.0 1501.0 1601.0
1701.0 1801.0 1901.0 2001.0 2101.0 2201.0 2301.0 2401.0
2501.0 2601.0 2701.0 2801.0 2901.0 3001.0 3101.0 3201.0
3301.0 3401.0 3501.0 3601.0 3701.0 3801.0 3901.0 4001.0
4101.0 4201.0 4301.0 4401.0 4501.0 4601.0 4701.0 4801.0
4901.0 5001.0 5101.0 5201.0 5301.0 5401.0 5501.0 5601.0
5701.0 5801.0 5901.0 6001.0 6101.0 6201.0 6301.0 6401.0
Matrix B
MFPT Used
Matrix C - Result
13826808.0 14187608.0 14548408.0 14909208.0 15270008.0 15630808.0 15991608.0 16352408.0
32393208.0 33394008.0 34394808.0 35395608.0 36396408.0 37397208.0 38398008.0 39398808.0
50959608.0 52600408.0 54241208.0 55882008.0 57522808.0 59163608.0 60804408.0 62445208.0
69526008.0 71806808.0 74087608.0 76368408.0 78649208.0 80930008.0 83210808.0 85491608.0
88092408.0 91013208.0 93934008.0 96854808.0 99775608.0 102696408.0 105617208.0 108538008.0
106658808.0 110219608.0 113780408.0 117341208.0 120902008.0 124462808.0 128023608.0 131584408.0
125225208.0 129426008.0 133626808.0 137827616.0 142028416.0 146229216.0 150430016.0 154630816.0
143791616.0 148632416.0 153473216.0 158314016.0 163154816.0 167995616.0 172836416.0 177677216.0
Press ESC to Exit...
Therefore different results !!!
and the DEBUG for win32 configuration :
Test-Case 1
Test-Case 2
Test-Case 3.1
Sub-Test 3.2
Test-Case 3.3
Test-Case 3.4
Test-Case 4
Matrix A
Matrix B
MFPT Used
Matrix C - Result
Finally with the flag fp:precision enabled I get the same resuling matrix the same size of long double (8), as before and very different and very different sub-test 3.2 result :
Sub-Test 3.2
Accuracy _PC_24 - long double - Result: 1.0090389251708984
All this is very confusing at this point. And it is a shame with all the effort you have put into this. One thing that I take from your notes is that probably /Qpc80 is the same as fp:extended flag ?
I do not have premium support so ..
Anyway, I am indebted for your help !
>> And a couple of more IDZ users...
goes w/out saying! Thank you all very much!
- « Previous
- Next »
