Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
memcpy causes an RTM abort?
I'm new in using intel tsx so, please correct me on any terminological/conceptional mistake.
I'm trying to use RTM on a project. I have multiple code segments causing a transaction failure and I'm trying to address those issues one by one. I have the following code segment,
int result=-1;
unsigned status;
while(result!=1){
   if ((status = _xbegin()) == _XBEGIN_STARTED) {
      memcpy(private_plaintext,private_decrypt,986);
      result=1;
      _xend();
   }else{
      printf("Block 1: Transaction failed\n");
     printf("status is %ld\n", status);
  printf("Block 1: Result is %d\n", result);
that memcpy is causing transaction failure. I'm getting the following output,
status is 0
Block 1: Result is -1
Any help, why this is happening and how can I solve it?
Thank you.
Highlighted
Hello Alam__Shariful,
Thank you for posting on the Intel® communities.
We are checking this thread and based on the details described we noticed that this seems to be related to the development of a software.
Based on that, we will move this thread to Software Products > Software Development Tools > Intel® C++ Compiler. However, there are several topics that you can choose based on your inquiry.
Sebastian M
Intel Customer Support Technician
Highlighted
Forwarding this thread to TSX subject matter experts(SMEs). They will get back to you soon.
Rahul
