Intel® C++ Compiler
miscompilation of int16_t division
Matthias_Kretz
Testcase:
[cpp]#include <iostream>
struct A
    short d[8];
    A() {}
    A(short a) {}
    A operator/(short x) const
        A r;
        r.d[0] = d[0] / x;
        r.d[1] = d[1] / x;
        r.d[2] = d[2] / x;
        r.d[3] = d[3] / x;
        return r;
A tmp;
int main()
    short divisor = 2;
    for (short scalar = -32768; scalar < -32700; scalar += 32) {
        A vector(scalar);
        tmp = vector / divisor;
        std::cout << scalar << " / " << divisor << " = " << scalar / divisor << "\n";
}[/cpp]
Compile without any extra flags for either -m32 or -m64 on Linux. This is what I get then:
[plain]-32768 / 2 = 16384
-32736 / 2 = 16400
-32704 / 2 = 16416[/plain]
The expected output is:
[plain]-32768 / 2 = -16384
-32736 / 2 = -16368
-32704 / 2 = -16352[/plain]
MalReddy_Y_Intel
Hi Mathias,
This seems  issue during the IPO,IL0 optimization phase in the presence of -O2,-O3 optimization switches.
Snippet of compilation optimization report at which incorrect results occur.
Routine _ZN1AC1Ev (1), (IP Summary), optimizing.
Routine _ZN1AC1Es (2), (IP Summary), optimizing.
Routine _ZNK1AdvEs (3), (IP Summary), optimizing.
Routine main (4), (IP Summary), optimizing.
Routine __sti__$E (5), (IP Summary), optimizing.
Routine __sti__tmp (6), (IP Summary), optimizing.
(IP optimizations) (7), optimizing.
Routine main (8), (IP Compile), optimizing.
Routine __sti__$E (9), (IP Compile), optimizing.
DOING [IPO] IP Const Prop Direct  (1)
DOING [IPO] DV Uplevel Subst  (2)
DOING [IPO] IP Const Prop Indirect  (3)
DOING [IL0] kstaticize locals  (4)
DOING [IL0] Substitution  (5)
DOING [PAROPT] PAROPT IL0 Restructuring  (6)
DOING [IL0] sincos promotion  (7)
DOING [IL0] IL0_PEEP_IDivs  (8)
DOING [IL0] Complex Lowering  (9) (last opt)
AVOIDING [IL0] SIMP  (10)
AVOIDING [IL0] il0_norm var replacement  (11)
I can also reproduce the issue, I will log defect and let you know more details once it is resolved.
Thanks for useful testcase.
Reddy
Matthias_Kretz
Thanks for taking it up. Do you have an idea for a workaround? This code appears in one of my unit test to create the reference data - my unit test fails because the reference is wrong...
MalReddy_Y_Intel
Current workaround can be compiling the source with -O1 or -O0 flag.
Matthias_Kretz
That's not an acceptable workaround. It would make the test significantly weaker. I need to be sure that everything works as expected at -O3.
Shenghong_G_Intel
You can add "#pragma optimize("", on|off)" to disable the part of code with optimization bug, and you can still use -O3 to compile other parts of code and run your testing.
some code...
#pragma optimize("", off)
this code with issues at O3
#pragma optimize("", on)
some other code...
Shenghong
MalReddy_Y_Intel
This is a signed overflow issue with loop normalization, Its implemented and targeted for
upcoming 14.0 branch (Ref Defect:DPD200249862 ).
Reddy
bernaske
Hi
i compiled the sample with
icc (ICC) 14.0.1 20131008
Copyright (C) 1985-2013 Intel Corporation.  All rights reserved.
under openSUSE Linux 12.3 , 13.1 and 13.2 ( Factory) the same problem works only correct with -O1 as option
does not correct work with -O3 -m64, only with -O1 -m64
regards
Franz
MalReddy_Y_Intel
This issue is fixed in latest 14.0 compiler, FYI.
Reddy
