Intel® C++ Compiler
_mm_set_epi16 problem with /arch:AVX and /arch:AVX2 under Visual Studio 17 (ICC19)
Wieckowski__Adam
Hallo,
I noticed a misbehavior when using _mm_set_epi16 with /arch:AVX(2). In debug mode I observe the following results of the following call:
mmTemp11 = _mm_set_epi16( 0, src11, 0, src10, 0, src11, 0, src10 );
-> mmTemp11.m128i_i16 0x00000074cf53bc80 {-2, -1, -2, 0, -2, 0, -2, 0}short[8] (for those unfamiliar with MSVC debugger, the problem is the bits 16:31 being set, when they clearly should be 0).
When src11=src10=-2. For positive values all works fine.
In release and profile configs I observe the program results being incorrect.
The problem does not occur with /arch:SSE42 or lower.
For now, I found the following workaround, but of course it would be nice if the program worked as intended:
mmTemp11 = _mm_cvtepu16_epi32( _mm_set_epi16( 0, 0, 0, 0, src11, src10, src11, src10 ) );
I don't think this behavior is intended. It works ok with gcc7/clang/msvc-19.16.
Compiler version is the one bundled with Intel Parallel Studio XE 2019.03.
Adam
Wieckowski__Adam
Found a minimal example to present the compiler bug. This only produces incorrect results when compiling with /Ob1, e.g.
icl /Ob1 /arch:CORE-AVX2 icc_bug.c
The following code demonstrates the problem:
#include <stdio.h>
#include <emmintrin.h>
void init_arr(short *arr)
  arr[0] = -2;
  arr[1] = -2;
int main()
  short arr[4];
  init_arr( arr );
  __m128i v = _mm_set_epi16( 0, arr[1], 0, arr[0], 0, arr[1], 0, arr[0] );
  int b0_31 = _mm_cvtsi128_si32( v );
  printf( "0x%x\n", ( b0_31 >> 16 ) & 0xffff );
Viet_H_Intel
I just wanted to clarify: the correct result should be zero and incorrect one should be 0xffff?
Wieckowski__Adam
Yes, exactly. The expected results is 0x0, but with the specified compiler options the output 0xffff is being produced.
Viet_H_Intel
I've reported this case to the Developer. Case number is CMPLRIL0-31587
Wieckowski__Adam
Is there anywhere I can follow the ticket?
Viet_H_Intel
This is for internal tracking only.
